Main : Mechanical : Engine exhaust leak?
[<   Previous  2206  2207  2208  2209  2210  2211  2212  Next   >]
exhaust leak?
exhaust leak?Popular
SubmitterkelmoMore Photos from kelmo   Last Update2007/7/19 14:34    Tell a friendTell a friend
Hits2923  Comments10    0.00 (0 votes)0.00 (0 votes)
there is a baffle in the exhaust man on US models that will wear a hole on the side. we are going to weld it up will post pic after
kelmo
Posted: 2007/7/21 16:35  Updated: 2007/7/21 16:35
 Re: exhaust leak?
The flange is in the exhaust manifold but does not bolt in. We have welded it in a closed position so as not to over heat the intake manifold. In a closed position it does not restrict exhaust flow.
P.S. Do you have any sources for a header in the states?
Thanks aLL,
Kelmo
bobs1200
Posted: 2007/7/21 22:59  Updated: 2007/7/21 22:59
 Re: exhaust leak?
headers in the states I have a nissan motorsports header I may sell but it may not clear factory intake it was designed to be used mikuni dual carb manifold. there is also one for sale on ebay
kelmo
Posted: 2007/7/20 18:22  Updated: 2007/7/20 18:22
 Re: exhaust leak?
Thanks for the help all. Forgot the welder today, so we'll try tomorrow. Think we are going to take it out and weld the hole on the side closed.
Dodgeman
Posted: 2007/7/21 0:32  Updated: 2007/7/21 0:32
 Re: exhaust leak?
I think that there is a bush in the hole, so you might need to push it out. I don't remember how hard this bush is, but something tells me that a drill is not going to do the job either.
The bush is made of a dis-similar metal to the cast, so trying to weld over it with the proper cast iron rod might be a problem.
Forewarned is forearmed.
kelmo
Posted: 2007/7/20 0:56  Updated: 2007/7/20 0:56
 Re: exhaust leak?
Yes, I mean flap valve(heat riser)..couldn't think of the word. If we weld that valve to one postion should it be open or closed? Or would it better to remove it completely?
The intake manifold has cooling fins on the bottom where the two meet together. The idea behind that valve is to help with cold start warm up...don't have much of a problem w/that in the desert
btw have not checked the year of the motor....got it out of a junk yard 20 some years ago.
Posted: 2007/7/20 2:25  Updated: 2007/7/20 2:25
 Re: exhaust leak?
It must be open ... it should only be closed for about 30 seconds while the engine is first started. You don't want to block your exhaust system.
You could take it out, or just wire it from the outside so it is stuck open.
FAZPIOES
Posted: 2007/7/20 13:41  Updated: 2007/7/20 13:41
 Re: exhaust leak?
Leave it ALL OPEN and weld it all around so it won
Dodgeman
Posted: 2007/7/20 13:49  Updated: 2007/7/20 13:49
 Re: exhaust leak?
These things are a pain when the shaft or bush becomes worn & the noise from the leaking manifold is irritating.
Interestingly, The A10 engine in Datsun 1000 coupes, & only the coupe version, did not have this flapper valve. They also used a free flowing dual outlet exhaust manifold.
This manifold also bolted to the inlet manifold's hot box in the same way as all the others & presumeably provided enough manifold heat, but without using a flapper valve.
If you live in a warm climate area, then removal of the flapper valve & shaft should not cause any real hardship.
kelmo
Posted: 2007/7/19 16:47  Updated: 2007/7/19 16:47
 Re: exhaust leak?
there was a discussion about exhaust leaks the other day about exhaust fumes in the cab of the car, just thought this could be another source of the leak. This is a US model a12
Posted: 2007/7/19 21:57  Updated: 2007/7/19 21:57
 Re: exhaust leak?
Looks like a 1971 manifold (1973 has cast cooling fins).
By "baffle" do you mean the flap valve (heat riser)? If this valve gets stuck partially closed it causes the manifold to overheat.
Even in normal operation, the valve shaft can wear and then blow out. Lubricating this every 12 months is part of the Periodic Maintainence of your 1200. See "exhaust manifold heat control valve":
wiki - Owner's manual
bobs1200
Posted: 2007/7/21 3:48  Updated: 2007/7/21 3:48
 Re: exhaust leak?
that flanges is the one that bolts to bottom of intake coerrect? if so and you weld it, you want to weld in a position to limit exhaust from bottom of manifold for a cooler intake charge.
best solution is to replace manifold with a exhaust header.
