Main : Misc South Africa, Centurion Bakkie
[<   Previous  2552  2553  2554  2555  2556  2557  2558  Next   >]
South Africa, Centurion BakkiePopular
SubmitterCliveMore Photos from Clive   Last Update2007/8/6 4:21    Tell a friendTell a friend
Hits2214  Comments4    10.000010.00 (1 vote)
A14, A12GX head(ported, flowed), 300 deg cam( Cam Shafts Dynamics), customBranch and freeflow(Speed Spot) and 2 40 mm weber side draughts ^__^ = fun
Clive
Posted: 2007/8/8 7:05  Updated: 2007/8/8 7:05
 Re: South Africa, Centurion Bakkie
Yes, will post pics 2morrow during the day. Going 2 do things diffrently this time around, but i can add it did go like hell.
WhiteSedan
Posted: 2007/8/7 23:08  Updated: 2007/8/7 23:08
Clive, Ive noticed you have the vacuum hooked up from the distributor, where does it go to. Also why did you not rubber mount the carbs, they can crack at the mounting tab from vibrations. Also you can get fuel foaming due to vibrations.
Cheers
Clive
Posted: 2007/8/8 4:48  Updated: 2007/8/8 4:48
hey, the vacuum hooks up to my master side draught, and yes I needed the O-ring rubber kit that goed in between the carbs and intakes. And lol.... it did brake. Will post a pic showing you just now.
WhiteSedan
Posted: 2007/8/8 5:51  Updated: 2007/8/8 5:51
Damn, did you get the tab welded up?
Also can you post a pic where you ran the vacuum?
