Main : Misc : Forum New A15
[<   Previous  183  184  185  186  187  188  189  Next   >]
New A15
New A15Popular
SubmitterXII00More Photos from XII00   Last Update2007/9/13 9:09    Tell a friendTell a friend
Hits2591  Comments25    0.00 (0 votes)0.00 (0 votes)
Finally, It's in and running.
SA_Bakkie
Posted: 2007/9/14 9:12  Updated: 2007/9/14 9:12
 Re: New A15
You must let us know some figures if you could .... I am really continplating this setup for my new bakkie.
XII00
Posted: 2007/9/18 9:44  Updated: 2007/9/18 9:44
 Re: New A15
Do you want specs on the engine components (pistons cam etc)
Or performance figures (H.P etc)?
Dundee1000
Posted: 2007/9/18 9:46  Updated: 2007/9/18 9:46
 Re: New A15
Both?
SA_Bakkie
Posted: 2007/9/18 9:51  Updated: 2007/9/18 9:51
 Re: New A15
Hi there
i would like both specs if possible, that would be great .......
XII00
Posted: 2007/9/18 14:57  Updated: 2007/9/18 14:57
 Re: New A15
Well, here goes, I'll start at the bottom.
Reground crank, flat tops, 40/80 cam, double valve springs, slightly larger valves-(don't ask me what they are off),fairly generously ported head, cc'd chambers.
radiused lifters, bushes instead of the springs on the valve train.
10.1:1 comp, pointless ignition, lightned flywheel, xtreme clutch.
Pistons, crank, rods,flywheel & clutch all balanced by veem.
Ceramic coated extractors, 2" exhaust into 3" dump pipe.
Carbs are 40mm Dellortos on a redline manifold. 6psi fuel pump (electric)
I think that's it?
It is only just run in, and the carbs have not been tuned yet.
So h.p?? <Dunno>
It seems to go pretty hard.
I haven't taken it past 4-5k rpm yet.
WhiteSedan
Posted: 2007/9/18 15:03  Updated: 2007/9/18 15:03
 Re: New A15
Sounds and looks the goods mate, are you running a regulator, what pump? 6psi will overload the needle and seat, I run 1.5psi with my dellortos but with a piersburg pump that flow enough for over 200hp.
Team_Dat
Posted: 2007/9/18 15:31  Updated: 2007/9/18 15:31
 Re: New A15
this is still porn to me!
can't wait to see it in the flesh!
XII00
Posted: 2007/9/18 15:44  Updated: 2007/9/18 15:44
 Re: New A15
Yeah, pump runs 6psi max.
Usually when running, gauge shows 3-4psi.
I think it has an internal regulator?
I can't remember the name of the pump manufacturer. I have chucked most of the reciepts for the engine build because if I added them all up, I would probably cry!, I no it is not a facuet type pump.
It is a cylindrical screw type???
Got it from holley parts. Locally.
WhiteSedan
Posted: 2007/9/18 15:51  Updated: 2007/9/18 15:51
 Re: New A15
Yeah most holley pumps come with a reg as well, when you have it tuned they will set it all up then. Must say it looks tops with all the cad plating, I would quite happily eat my breakfast off that.
XII00
Posted: 2007/9/18 15:56  Updated: 2007/9/18 15:56
 Re: New A15
Before I had the extractors ceramic coated, you could have had a nice bbq on the intake manifold!
kululadotgroen
Posted: 2007/9/13 21:31  Updated: 2007/9/13 21:31
 Re: New A15
Fcuk that's neat!!!
pitanando
Posted: 2007/9/13 23:13  Updated: 2007/9/13 23:13
 Re: New A15
is it " vergine " ?!
the engine look
Ronny_CTS
Posted: 2007/9/13 18:04  Updated: 2007/9/13 18:04
 Re: New A15
This is Porn! I cant stop looking at it...
SA_Bakkie
Posted: 2007/9/13 10:21  Updated: 2007/9/13 10:21
 Re: New A15
Very very nice, I am looking at the same sort of set up for mine .... Would like to know some performance figures if you can. But WELL DONE VERY NICE INDEED.
2332owner
Posted: 2007/9/13 13:23  Updated: 2007/9/13 13:23
 Re: New A15
Dead sexy.
Well done!
Team_Dat
Posted: 2007/9/13 14:05  Updated: 2007/9/13 14:05
 Re: New A15
you have a PM
kelmo
Posted: 2007/9/13 14:08  Updated: 2007/9/13 14:08
 Re: New A15
I think I want to marry that engine bay. Very nice indeed, good work!!!
Velociti
Posted: 2007/9/13 9:30  Updated: 2007/9/13 9:30
 Re: New A15
The engine bay still looks as new as my 2006 ute,
with 65000km on the clock.
XII00
Posted: 2007/9/13 9:34  Updated: 2007/9/13 9:34
 Re: New A15
I will post some more pics of the rest of the ute soon.
Team_Dat
Posted: 2007/9/13 9:43  Updated: 2007/9/13 9:43
 Re: New A15
WOO and he's from Perth! fantastic!
XII00
Posted: 2007/9/13 9:50  Updated: 2007/9/13 9:50
 Re: New A15
WA born and bred.
XII00
Posted: 2007/9/13 9:40  Updated: 2007/9/13 9:40
 Re: New A15
Wish we could get a 2006 model ute here.
Team_Dat
Posted: 2007/9/13 9:24  Updated: 2007/9/13 9:24
 Re: New A15
did you just find that car out the back of the nissan plant in a sealed box?
thats amazing!
fantastic job!
XII00
Posted: 2007/9/13 9:27  Updated: 2007/9/13 9:27
 Re: New A15
Thanks guys.
Na it didn't come in a sealed box, but the car has only done 52,000km from new.
It has always been garaged.
J-dat
Posted: 2007/9/13 9:22  Updated: 2007/9/13 9:22
 Re: New A15
That is awesome... Well done.
Velociti
Posted: 2007/9/13 9:20  Updated: 2007/9/13 9:20
 Re: New A15
Very neat workmanship.
Nice job.
1200rallycar
Posted: 2007/9/13 9:19  Updated: 2007/9/13 9:19
 Re: New A15
VERY IMPRESSIVE
pager
Posted: 2007/9/14 9:25  Updated: 2007/9/14 9:25
 Re: New A15
I love it. Would be to scared to drive it but
kue1000
Posted: 2007/9/18 10:13  Updated: 2007/9/18 10:13
 Re: New A15
very schmick!
such a clean and neat engine bay - thought mine was tidy till i saw this - i can see i have more work to do!
