Main : Mechanical : Engine grind off valve seat?
[<   Previous  2099  2100  2101  2102  2103  2104  2105  Next   >]
grind off valve seat?Popular
Submitterdongdong0507More Photos from dongdong0507   Last Update2007/10/25 9:26    Tell a friendTell a friend
Hits3229  Comments4    0.00 (0 votes)0.00 (0 votes)
the yellow and red area are valve seat. i found that yellow area are rather useless, then can i grind off this part? any side effect? air flow will be better?
killer1200
Posted: 2007/10/25 15:08  Updated: 2007/10/25 15:08
 Re: grind off valve seat?
That pic is not really right as the seat is strait, like a tube.
If you've never ported a head it would be a very bad idea to start on the seat area as you will get in to trouble very fast.
dongdong0507
Posted: 2007/10/25 15:33  Updated: 2007/10/25 15:33
yes i will port the head soon.
sunny_coupe110
Posted: 2007/10/25 10:00  Updated: 2007/10/25 10:00
You had better not sharpen the valve seat very much.
There is the case that a problem is over in strength.
When a valve seat sinks into the cylinder head, there is it.
Quinn
Posted: 2007/10/25 13:35  Updated: 2007/10/25 13:35
I have spoken to quite a few guys about the venturi affect (when a tube is tapered it forces the air to speed up) around the valve seat and I have been warned against removing to much material as it promotes slower air flow (not a problem if you are running a turbo), just something to think about.
