Main : Mechanical : Engine Two types of fans
[<   Previous  2144  2145  2146  2147  2148  2149  2150  Next   >]
Two types of fans
Two types of fansPopular
SubmitterTurboronMore Photos from Turboron   Last Update2007/12/5 19:46    Tell a friendTell a friend
Hits2638  Comments5    0.00 (0 votes)0.00 (0 votes)
the fan on the left I think is from an AC equiped car
Lotto
Posted: 2008/1/29 21:17  Updated: 2008/1/29 21:17
 Re: Two types of fans
my Datsun its from 1973 and it
Posted: 2008/1/30 1:48  Updated: 2008/1/30 1:48
There are four types of fans for RWD A-series engines:
1. Lo-output engine: 310 mm diameter plastic (used on A10/A12/A13/A14/A15)
2. High-output engine: 330 mm diameter plastic
3. PB310 and HB310: 350 mm diameter - steel, 7 blades
4. Electric fan: 320 mm diameter, steel 5-blade (some 1980-1982 B310s)
In USA, A/C 1200s got a flexi-fan (fibreglas blades), while B210, B310 used #2 above.
I'm thinking the 6-blade fan is from another car or is a generic (you can see the bolt holes are slotted to fit different engines).
Velociti
Posted: 2007/12/7 7:45  Updated: 2007/12/7 7:45
The UTE's in South africa still come out of the factory with the plastic one on the right. See pic below.
beattie
Posted: 2007/12/7 11:57  Updated: 2007/12/7 11:57
i would say the black one is aftermarket. one of those nasty universal ones.
