Main : Misc : Forum engine eye candy
[<   Previous  156  157  158  159  160  161  162  Next   >]
engine eye candy
engine eye candyPopular
SubmitterpickoMore Photos from picko   Last Update2007/12/17 12:45    Tell a friendTell a friend
Hits2698  Comments16    0.00 (0 votes)0.00 (0 votes)
a15 + asmuch fruit as a tree can handle
andoa
Posted: 2008/8/30 9:11  Updated: 2008/8/30 9:11
 Re: engine eye candy
man thats awesome looken forward to see wat it does on the dyno
reuby_tuesday
Posted: 2008/8/30 9:19  Updated: 2008/8/30 9:19
a question on the efi
i was under the impression that you want the injectors as close to the combustion chamber as possible, with them pointed at an angle so that they squirt as directly as possible into the chamber.
This setup has them a fair way back. Is there a reason for this? or is it just a case of thats the package that they sell.
cheater_5
Posted: 2007/12/18 5:07  Updated: 2007/12/18 5:07
something else i noticed, was the different rocker pedestals. Did the assemly come as a package with the rolelr rockers or was that custom made?
Looks the freaking tits man
picko
Posted: 2007/12/18 6:17  Updated: 2007/12/18 6:17
all as a package
Dodgeman
Posted: 2007/12/17 14:05  Updated: 2007/12/17 14:05
What's the story with the rockers? They don't look like the Yella Terra ones that I'm familiar with.
It looks like it's gonna boogie once it's up & running.
datsun150
Posted: 2007/12/17 20:51  Updated: 2007/12/17 20:51
cool! where didyou get the efi kit from
TnPshow
Posted: 2007/12/17 22:56  Updated: 2007/12/17 22:56
That crank angle sensor looks like a 13B one?
I've played a bit with these - the standard A series cam gear fits on the shaft...
Nice work - I like what I see!
picko
Posted: 2007/12/18 2:16  Updated: 2007/12/18 2:16
yes it is from 13bt. most shafts are 1/2in in size so it is just a matter of changing cogs. the efi is from efi hardware. wot you dont see is a disco potatoe going on the side. the motor is built for 30psi. price tag??? lots
TnPshow
Posted: 2007/12/18 2:23  Updated: 2007/12/18 2:23
That's a pretty serious piece of hardware!
Do you reckon a Disco Potato would be a bit too laggy?
picko
Posted: 2007/12/18 2:27  Updated: 2007/12/18 2:27
no i have something very similar on my a14 ute at the moment and it is on full boost just under 4000rpm (12psi). very drivable. feels like a 2 stroke. this motor is punched out to 156? and has a smaller air ratio on the back than my ute so at 15 psi for the street should be quite responsive... aside from traction.
dodgeman... i am not familar with any other rola rockers. these are 1.55 ratio perhaps they have changed them a little?
tens_and_twenties
Posted: 2007/12/18 3:17  Updated: 2007/12/18 3:17
All that money and you can't afford proper shoes?
picko
Posted: 2007/12/18 4:39  Updated: 2007/12/18 4:39
that is standard ppe here mate!
picko
Posted: 2007/12/17 12:46  Updated: 2007/12/17 12:46
cool! it worked!
ZigZag
Posted: 2008/8/30 12:49  Updated: 2008/8/30 12:49
that is sexual!
Quinn
Posted: 2008/8/30 16:57  Updated: 2008/8/30 16:57
I was told that if you set up your injectors further away from the port and have long induction tubes you gain torque and a bit more hp as the fuel mixes better with the air, how ever you loose a bit of responsiveness...
How ever if he is running at least 15psi I dont think it will matter where the injectors are as its all going to be forced in pretty hard anyway.
