Main : Mechanical Horn Relay
[<   Previous  357  358  359  360  361  362  363  Next   >]
Horn Relay
Horn RelayPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2007/12/27 7:47    Tell a friendTell a friend
Hits3610  Comments6    0.00 (0 votes)0.00 (0 votes)
Wire Colors: Green, Green/White stripe and Black/green stripe.
Velociti
Posted: 2007/12/29 9:07  Updated: 2007/12/29 9:07
 Re: Horn Relay
Ive got 2x Airhorns on a small electric compresser. Only draws 1.2 Amps.
Being in South Africa, I'm sure you have to use the horn a lot for wild animals.
We dont need load horns for animals here in SA, they are for the minibus taxi's which are everywhere.
kululadotgroen
Posted: 2007/12/29 0:03  Updated: 2007/12/29 0:03
 Re: Horn Relay
Oooo, is that what that was. I couldn't figure out what it was for when I redid my wiring, so I threw it out. The horn now runs of the green/white and black/green wires directly...
dattodude
Posted: 2007/12/29 0:23  Updated: 2007/12/29 0:23
 Re: Horn Relay
I'd look into either fixing it...or using a later model horn from another car that draws less current.
I used a toyota AE86 horn (was laying around), it draws about 2 amps, and it works fine without a relay.
Posted: 2007/12/29 4:50  Updated: 2007/12/29 4:50
 Re: Horn Relay
Indeed. Datsun 1200 horns each draw 5 Amps (spiral type horns). That's 10 AMP through the the horn button, probably will burn out sooner or later.
Posted: 2007/12/28 0:23  Updated: 2007/12/28 0:23
 Re: Horn Relay
The Horn Relay is located here in a stock Datsun 1200:
