Main : Mechanical : Engine Ipra Coupe, a little more progress
[<   Previous  2139  2140  2141  2142  2143  2144  2145  Next   >]
Ipra Coupe, a little more progressPopular
SubmittersikyneMore Photos from sikyne   Last Update2008/1/1 1:30    Tell a friendTell a friend
Hits3116  Comments5    0.00 (0 votes)0.00 (0 votes)
The start of the inlet maifold and turbo manifold. the timing chain sprockets are getting made at the moment. still a long way off running!!
LAGWAGON
Posted: 2008/1/1 10:32  Updated: 2008/1/1 10:32
 Re: Ipra Coupe, a little more progress
its an a14 with a twin cam motorbike head on it, efi turbo. lots of things needed to put it on, so its no bolt on job, but it will work!
sikyne
Posted: 2008/1/1 10:41  Updated: 2008/1/1 10:41
Hi Leigh, Happy new year! Ive pulled the front end out since this photo to get stuff electroplated. Does anyone in Melb know the best place to get stuff plated??
sidedraught
Posted: 2008/1/1 10:51  Updated: 2008/1/1 10:51
Jesus Christ!........ now I really have seen everything.
sikyne
Posted: 2008/1/2 0:46  Updated: 2008/1/2 0:46
It is a bit different.. Im puting 4 injectors on the bends in the intake runners and 4 in the plenum, i would have loved to keep the runners straght but no room under the bonnet.The runners are 18" long.
It should make about 300hp at 8400rpm, a 36mm mandatory restrictor will limit the output to somewhere near this.
L18_B110
Posted: 2008/1/2 3:31  Updated: 2008/1/2 3:31
looking good! is that a blade adjustable type front sway bar I see?
can't wait for this beast to hit the track. I think the 1200cc turbo is a great formula for IPRA - an U2L car with potential to win outright!
sikyne
Posted: 2008/1/2 9:05  Updated: 2008/1/2 9:05
Na, I Sold the blade to a mate in Kyneton. It was too long by about 50mm to work properly. The one in the pic is still very adjustable. It`s 1+1/8" x .065" 4130 tube with adjustable and removable end arms, so i can also go up or down a bar size very quickly during a practice session. And all still lighter than the standard bar..Are you still racing??
sikyne
Posted: 2008/1/1 2:02  Updated: 2008/1/1 2:02
The engine is tilted toward the LHS to ensure the water outlet in the head is at the highest point to prevent air pockets being trapped.
LAGWAGON
Posted: 2008/1/1 10:27  Updated: 2008/1/1 10:27
looking good mate, that elaborate plenum design of yours will be a sight to see
frankthedolphintrainer
Posted: 2008/1/1 10:28  Updated: 2008/1/1 10:28
what sort of engine is it? is it a sr
