Main : Misc blown head gasket
[<   Previous  1986  1987  1988  1989  1990  1991  1992  Next   >]
blown head gasket
blown head gasketPopular
Submitter12undiesMore Photos from 12undies   Last Update2008/1/2 11:39    Tell a friendTell a friend
Hits1691  Comments3    0.00 (0 votes)0.00 (0 votes)
found the problem finally i thought it was the carby  but turns out no wat could cas this cheap gasket to much revving or just were and tare wat you guys think
Posted: 2008/1/2 17:36  Updated: 2008/1/2 17:36
 Re: blown head gasket
When I was first starting out, an old mechanic told me the most common cause is grease or old gasket left on when fitting a new head gasket.
He recommended wiping the block and head face using ether (alcohol), and scraping the faces until they were absolutely clean. I've always followed his advice and never had a blown gasket, more than 25 years now.
The other common causes are:
- Not torquing the bolts in the right pattern
- Not using a torque wrench
- Overheating of the engine (run out of coolant)
kegs
Posted: 2008/1/2 13:48  Updated: 2008/1/2 13:48
you might get better results to your question if people can read what u type. but i reckon if it was a cheap gasket and you were revving it hard its probably no wonder that it blew.....
