Main : Misc which one has better airflow?
[<   Previous  1985  1986  1987  1988  1989  1990  1991  Next   >]
which one has better airflow?Popular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2008/1/3 1:22    Tell a friendTell a friend
Hits2290  Comments18    0.00 (0 votes)0.00 (0 votes)
the one on the left is a ca18 throttlebody and the one on the right is the stock a14 efi. i would think that the ca one is better and i feel it would be an easy fit just by making a spacer, its going on the a14 plenum
sunny
Posted: 2008/1/4 12:20  Updated: 2008/1/4 12:20
 Re: which one has better airflow?
the primary hole was about 10 or 12 mm so i had it machined out to what is now the bigger throttle body is too big for the street it is not nice to drive and doesn't give you more power it just gives it to you all at once. the 55mm will flow more air than the thing needs at about 1/4 throttle opening if you want a plate to try it you can.
Posted: 2008/1/3 1:34  Updated: 2008/1/3 1:34
the ca throttle body has a 55mm opening and the a14 has two holes 26 and 37mm.
the way i work it if i remember from school as the ca would be
pie r squared= 1590.43 mm
and the a14 would be
(pie r squared)+(pie r squared)=530.93+1075.21=1606.14
according to this the a14 would be better
i dont understand how a 1.4lt engine throttle body designed so long ago would be better than a 1.8lt throttle body design at a much later date
Posted: 2008/1/3 1:41  Updated: 2008/1/3 1:41
Under 5000 RPM, undoubtedly the A14 one flows better in actual conditions. Above that I would hazard a guess that the CA one is better.
On a flowbench obviously the larger one will flow better. But that doesn't mean it will make more power on a small-bore piston engine.
reuby_tuesday
Posted: 2008/1/3 4:13  Updated: 2008/1/3 4:13
Is the reason for the two butterflys is a primary/secondary setup like carbs have?
I would think that the ca one will flow better because there is less surface area to create friction, ie turbalance.
But with that in mind, I agree with dd. having massive airflow is not always ideal for a small bore engine doing small revs, but higher up then having the massive airflow can be benifical. I guess it depends on the application too.
A larger bore will have less velocity but more cc of air per section, where as a smaller one would have greater velocity, but less cc per section.
The two could in fact have the same total volume thru them over the rev range.
Does that make sense?
Posted: 2008/1/3 4:35  Updated: 2008/1/3 4:35
yeah the two butterflys are primary and a secondary
kululadotgroen
Posted: 2008/1/3 7:15  Updated: 2008/1/3 7:15
Remember that even though the surface area might be bigger, it might still not flow more. Airflow through a hole goes up exponentially as the hole size goes up. Also for outright flow the CA one will work better as there is less interference from metal parts like in the A14 one. Though for in town driving you might find that the A14 one will be better, as you'd get better low end torque with the smaller port, and it won't be as "nervous", since small throttle changes translates to small air flow changes.
LittleFireyOne
Posted: 2008/1/3 9:05  Updated: 2008/1/3 9:05
If you feel you want an in between you go with the CA item and make yourself an inlet restrictor bellmouth to stick in there?
Posted: 2008/1/3 9:22  Updated: 2008/1/3 9:22
its only gonna cost a couple of $ to change over so i feel why not ca throttle body it is
NIS2000
Posted: 2008/1/3 10:08  Updated: 2008/1/3 10:08
CA one actually works out at 2374mm squared. I can see from the picture which one has the biggest surface area so i rechecked your calcs and thats what i got.
Posted: 2008/1/3 10:25  Updated: 2008/1/3 10:25
ha so it is thats what being out of school for 7 years does to you. how smart am i, i used 22.5 as half of 55
Dodgeman
Posted: 2008/1/3 11:08  Updated: 2008/1/3 11:08
The A14 for driveability, but lower max output, the CA for higher max output, but lower driveability.
Incidentally, the spelling is Pi, not pie. Pie's are what you eat.
dattodude
Posted: 2008/1/3 12:58  Updated: 2008/1/3 12:58
Remember the CA one has 12 pounds of boost behind it. A lot more 02 molecules are going through at the same air velocity.
I am just throwing in a discussion point on:
Q: 'When sizing a throttle body, does air pressure or density affect flow?'
I don't really know the answer.
1200rallycar
Posted: 2008/1/3 15:13  Updated: 2008/1/3 15:13
im guessing the dolphin trainer will be boosting this
other things to condier may be what connections you need and what computer etc
i made a plate to mount a camira throttle body to my a-series injection manifold as i used the camira computer everyhing plugged straight up and TPS was obviously already setup for that computer
{edit} oh yeah and just remembering the opening of the a-series manifold is quite an odd shape so you may end up with some horrible steps in your conection which will mean poor air flow between the two
i ported the opening of the manifold in some areas and actually used some metal goo to build some slope into the manifold to avoid steps in other areas
i also ported and knife edged the throttle body to improve flow... but that was probably a waste of time
B210sleeper
Posted: 2008/1/3 18:50  Updated: 2008/1/3 18:50
there's always the GA16 throttle body, i used one of those since i had one laying around.
Posted: 2008/1/3 22:48  Updated: 2008/1/3 22:48
its definetely for boosted application, and if you look at the plenum side the opening hole (bottom of the pair shape) is the exact same size as the ca throttle body, to answer the question about sensor and such for the computer all are on the plenum side.
Cameron_Datto
Posted: 2008/1/4 19:55  Updated: 2008/1/4 19:55
On a flow bench if you compare a Single pipe with 2 pipes of the same cross sectional area to the single pipe , the Single Pipe will always flow more air.
If your looking for a twin throttle body up grade . Might be worth looking at a Holden Camira throttle body .
1200rallycar
Posted: 2008/1/5 3:44  Updated: 2008/1/5 3:44
i run a JE camira throttle body, its single butterfly, maybe the earlier is a twin?
