Main : Members : WhiteSedan More racecar goodies
[<   Previous  42  43  44  45  46  47  48  Next   >]
More racecar goodiesPopular
SubmitterWhiteSedanMore Photos from WhiteSedan   Last Update2008/2/4 7:08    Tell a friendTell a friend
Hits1931  Comments2    0.00 (0 votes)0.00 (0 votes)
Nismo .250+ retainers, nismo springs + cam to suit. This will go in on first rebuild as I need to check for valve clearance as this cam makes .610 lift at the valve, pistons will probably need to be fly-cut.
WhiteSedan
Posted: 2008/2/5 11:54  Updated: 2008/2/5 11:54
 Re: More racecar goodies
Doh!!
The pic I first put up has L18 SSS cam.
This is the pic with the correct cam, you will notice the ground basecircle on the race cam, this requires much thicker lash pads to correct lobe position on the rocker arm hence the special retainers.
Lash pads cannot be ordered until the cam is in the head and setup.
