Main : Misc : Tech Section AISIN clutch disk
[<   Previous  213  214  215  216  217  218  219  Next   >]
AISIN clutch disk
AISIN clutch diskPopular
SubmitterDatsunSSSMore Photos from DatsunSSS   Last Update2008/2/7 21:04    Tell a friendTell a friend
Hits2275  Comments6    0.00 (0 votes)0.00 (0 votes)
sunny
Posted: 2008/2/8 12:58  Updated: 2008/2/8 12:58
 Re: AISIN clutch disk
all good til you want to drive it properly. then when it slips you will have to buy a good one.
Posted: 2008/2/8 17:59  Updated: 2008/2/8 17:59
Sunny, are you saying this clutch disk is not good enough for an A12? If I recall correctly, datsunSSS's B210 has an A12 engine.
I would certainly trust it for a "properly driven" A12. That means no riding the clutch. No burnouts. No full-throttle clutch dumps. Some partial-throttle dumps to get going won't hurt it.
DatsunSSS
Posted: 2008/2/8 19:43  Updated: 2008/2/8 19:43
i use one of this in my a14 and its fine, i constantly dump the clutch but she
Posted: 2008/2/7 21:38  Updated: 2008/2/7 21:38
This is a high-quality unit. It has six steel springs in the hub.
Cheap clutches have only 4 springs.
The springs are especially important with lightened flywheels as they take up the shock and vibration from the engine. Some Nissan ones had some steel springs and rubber pellet springs to make it smoother, but I think the rubber gets weak over time.
DatsunSSS
Posted: 2008/2/7 23:47  Updated: 2008/2/7 23:47
Yes this is a good clutch, but it was cheap.
this clutch set cost me +- 145USD
" clutch, clutch cover and bearing"
