Main : Members : ANGE : Other my dattos3
[<   Previous  28  29  30  31  32  33  34  Next   >]
my dattos3
my dattos3Popular
SubmitterANGEMore Photos from ANGE   Last Update2008/2/9 6:00    Tell a friendTell a friend
Hits3310  Comments9    0.00 (0 votes)0.00 (0 votes)
a12 sedan, 12a ute.
FRKYCA
Posted: 2008/2/9 11:52  Updated: 2008/2/9 11:52
 Re: my dattos3
best of both worlds ?
love the ute man, and looking at the sedan,makes me miss mine.
dattodude
Posted: 2008/2/9 12:00  Updated: 2008/2/9 12:00
 Re: my dattos3
Sedan's are awesome! They do look good together.
ps. I'm totally biased on the Sedan thing.
pps. I remember a time when I thought the sedans 'looked uncool' and so much preferred the Coupe or Ute. Found a Sedan with an A14 for $1000 ..the rest is history.
FAZPIOES
Posted: 2008/2/9 20:20  Updated: 2008/2/9 20:20
 Re: my dattos3
are the sedan wheels 13? 14? 15?
Mitch_photog
Posted: 2008/2/9 22:49  Updated: 2008/2/9 22:49
 Re: my dattos3
Yeah they look good together, especially because there both yours...
pepper
Posted: 2008/2/9 23:20  Updated: 2008/2/9 23:20
 Re: my dattos3
are those simmons 3 peice?
if they are what struts are you using and the measurements of the outer rim?
ANGE
Posted: 2008/2/10 8:09  Updated: 2008/2/10 8:09
 Re: my dattos3
sedans running 15inch saab chasers
3 piece simmons on the ute with a 2 inch outer rim, on 120y struts with s13 brakes.
front guards are pumped out a fair bit, wouldnt fit 2 inch outers with this setup on standard guards.
pepper
Posted: 2008/2/11 7:01  Updated: 2008/2/11 7:01
 Re: my dattos3
does using that front strut brake combo increase your track??
how did you go with the footwell fouling on the tyres?
im using 15x7 b45's on front and hoping that by using 195/50's will keep me clear of too many issues there
ANGE
Posted: 2008/2/11 11:10  Updated: 2008/2/11 11:10
 Re: my dattos3
when using s13 brakes the disc slides over the 120y hub onto the wheel studs. so you get a minor track increase (7mm) due to the thickness of the mounting face of the disc.
i get a tiny bit of friendly rubbage only in the footwell area and only when at full lock. but i run a 5.5inch front rim with 175/55 tyre, 50's would fix this. Or perhaps limiting the turning circle, but that would be uncool.
ive got a 205/50 on 6.5inch rim on the rear.
a 7 inch wheel on the front of a 1200 without major rubbage would be an acheivement to say the least!
im assuming you know the correct way to measure a wheel, cos if youve just
measured the overall width of the rim then id say you probably have 15x6 wheels (a good thing)
but anyway, the beauty of simmons is that you can modify them to suit.
good luck with it
b45's will look mint
