Main : Members : frankthedolphintrainerm still not happy
[<   Previous  63  64  65  66  67  68  69  Next   >]
still not happy
still not happyPopular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2008/2/14 0:33    Tell a friendTell a friend
Hits1879  Comments8    0.00 (0 votes)0.00 (0 votes)
as you can see my a12 still isnt doing what i want it to. by the graph you may notice the slight bump,lol, we suspect this is caused by the tiny little exhaust (2 inch) i am currently running, the back pressure is preventing it going up any higher.
Posted: 2008/2/14 0:36  Updated: 2008/2/14 0:36
 Re: still not happy
all the stats are incorrect at the top aswell, you may also notice my original thoughts that the turbo was only 13 psi are a little wrong its now up to 15.34 psi.
you mightalso just be able to read how hot it is today it recorded 33.4 degrees celcius and 59% humidity, you could say its just a little bit warm (good old townsville)
tappet
Posted: 2008/2/14 0:41  Updated: 2008/2/14 0:41
 Re: still not happy
get a 3" at least if u want top end power..
not a bad figure for a carby setup..
Posted: 2008/2/14 0:43  Updated: 2008/2/14 0:43
 Re: still not happy
i would have thought a 2.5inch would be best for the 1.2lt
Posted: 2008/2/14 5:10  Updated: 2008/2/14 5:10
 Re: still not happy
Very nice output from an A12.
Exhaust diameter is primarily sized to the horsepower output, not the engine size per se.
2.5" is way to big for a naturally aspirated A12. You can do it, but it won't make your car go faster, but a little slower than a smaller pipe.
But for turbocharged 1.2 -- like this one -- making 71kw (96 hp) at the rear wheels... let's see that might be around 125 hp at the flywheel ... it would call for at least a 2.25 inch exhaust. And if engine 'should' make more power then a 2.5 pipe might be called for, which should be good for 150-200 flywheel hp. Reference: club wiki - Exhaust Piping.
BUNDY351
Posted: 2008/2/14 6:49  Updated: 2008/2/14 6:49
 Re: still not happy
Hay, well done mate, finally got the beast on a dyno. Exhaust wise I would go to 2.5in if you plan to keep that size motor in that car. If you are planning to get a bigger donk in the future go a 3in and save the hassel down the track.
As for what ddgonzal said about 2.5in being way too big on a 1.2L NA motor I dissagree and so does my time slip. I went from 19's to 18's down the quartermile by removing the stock pipes and fitting my own 2.5in system.
Granted its a PIG down low and sounds like a killer wet fart it revs much more freely and has a little more top end pull
Posted: 2008/2/14 7:06  Updated: 2008/2/14 7:06
 Re: still not happy
Sorry I wasn't clear. I didn't mean that a 2.5" pipe was worse than the stock 1.5" pipe. I only meant that 2.5" is not optimum for a naturally aspirated A12. The 1.5" is too small for max HP if you rev (even a totally stocker engine) up high.
Do this: Dyno your stock A12 (or drag time it) with 2.5". Then, same hour, swap to full 2" system and see if it goes slower. I doubt it. I would expect it to be no slower, and run slightly better at lower RPM.
kululadotgroen
Posted: 2008/2/14 7:44  Updated: 2008/2/14 7:44
 Re: still not happy
As ddgonzal said, on NA you could go to big, but for a turbo motor, the best exhaust is no exhaust. So taking into account regulations regarding noise, and that a turbo acts as a nice baffle, taking out that harsh engine note, you should try to go as large as possible. I currently run 63mm with the 4AGTE, but even a simple act such as placing a lambda sensor in the tailpiece drops the output by as much as 9hp, which should be a good indication why you must use the largest zorst possible.
EDIT: tappet, this is not a carby setup if memory serves me right...
AGAIN: yup, my brain still functions for a few minutes a day...
LAST ONE: I promise.... looking at this piccy, you should try to move your battery to the bin, and get the boost pipe shorter. Might score a few horses there...
