Main : Mechanical : Suspension can sombody explain this?
[<   Previous  331  332  333  334  335  336  337  Next   >]
can sombody explain this?Popular
SubmitterfrankthedolphintrainerMore Photos from frankthedolphintrainer   Last Update2008/2/23 22:38    Tell a friendTell a friend
Hits3606  Comments9    0.00 (0 votes)0.00 (0 votes)
i pinched this photo from ebay so if its yours sorry. but can sombody explain how this suspension setup works, as i can see its a r31 diff mini tubed with 4 link setup, what happened to the leafs or does the 4 link setup stop it from going side to side?
BUNDY351
Posted: 2008/2/24 0:41  Updated: 2008/2/24 0:41
 Re: can sombody explain this?
I understand what you are saying, there is no "WATTS LINK" or "PANHARD ROD" to stop the laterial movement (sideways) of the diff.
The only thing I can think of is it might be a work in progress/unfinished project.
Its a pretty sexy set up and its giving me some ideas but thats a long way away.
Posted: 2008/2/24 0:47  Updated: 2008/2/24 0:47
its supposed to be finished and drivable. i would be very intereste in seeing it i like the idea of springs and not leafs
phunkdoktaspok
Posted: 2008/2/24 3:08  Updated: 2008/2/24 3:08
You cant see if the top arms are triangulated or if there is a panhard bar in the front of the diff.
Posted: 2008/2/24 4:56  Updated: 2008/2/24 4:56
how does the panhard bar work?
killer1200
Posted: 2008/2/24 5:30  Updated: 2008/2/24 5:30
This 4 link does not run a sway bar but you can it would look something like this.(you have 2 one on each side of the case.
Tyrie
Posted: 2008/2/24 5:32  Updated: 2008/2/24 5:32
panhard rod goes from one side of the diff to the other side of the chassis, stopping side-side movement. I think it means when the suspension moves up and down the diff moves sideways with it?
I know with cars that have them standard they have to be replaced with adjustable ones when lowered as it pushes the diff to one side.
ps. There's a rear setup very much like this on a ute here in canberra, very sexy stuff
datb110
Posted: 2008/4/1 17:13  Updated: 2008/4/1 17:13
Quite a regular
The top links look to be triangulated so no panhard or watts link required. very good setup indeed should ride realy good.
tappet
Posted: 2008/4/1 21:47  Updated: 2008/4/1 21:47
triangulated top links will not stop the sideways diff movement if rod ends are used.
it may have a panhard rod hiding in there but i can't see it..
