Main : Misc Turbo manifold, T25 flange
[<   Previous  1759  1760  1761  1762  1763  1764  1765  Next   >]
Turbo manifold, T25 flangePopular
SubmitterFinTuukkaMore Photos from FinTuukka   Last Update2008/3/4 20:29    Tell a friendTell a friend
Hits3713  Comments10    0.00 (0 votes)0.00 (0 votes)
FinTuukka
Posted: 2008/3/4 20:33  Updated: 2008/3/4 20:33
Quite a regular
 Re: Turbo manifold, T25 flange
cheater_5
Posted: 2008/3/5 6:12  Updated: 2008/3/5 6:12
yea man that looks sick!
Keep it up
short-coupe
Posted: 2008/3/5 12:02  Updated: 2008/3/5 12:02
u need to rotate the centre housing,
beattie
Posted: 2008/3/5 12:22  Updated: 2008/3/5 12:22
Is that PCV hose going into the cabin
Nice long runners, looks like you are going custom inlet too, EFI?
kegs
Posted: 2008/3/5 23:41  Updated: 2008/3/5 23:41
good luck mate the first time this thing gets hot the whole thing is gonna just fall to ####, hate to tell you but u need to make it out of 4mm thick steel pipe not exhaust pipe the only way itcould maybe work is if you brace the turbo solidly to the engine even then i wouldnt run is. not baggin you out only trying to save you more hassles.
Burke_a_lot
Posted: 2008/3/6 1:16  Updated: 2008/3/6 1:16
a good paint job in that engine bay and your got yourself one good looking engine!
Boostin
Posted: 2008/3/6 3:26  Updated: 2008/3/6 3:26
I agree with Kegs,
When that gets hot its gonna sag really bad..
Trust me i did the same, then i made my next one out of steam pipe bends...
Looks the goods for sure but a tad too thin i think....
Cable_Tie
Posted: 2008/3/6 4:21  Updated: 2008/3/6 4:21
Is this stainless?
Can't argue with the previous ET's
FinTuukka
Posted: 2008/3/6 17:42  Updated: 2008/3/6 17:42
Quite a regular
Nopes, its not going to the cabin Heater hose is just temporarily leaning on the breather pipe.
Gonna go EFI later, megasquirt probably. I'm going to start with the original manifold, adapter plate and weber DAT 32 turbo carburettor.
Ok. This is the first tbo manifold I ever built. I pretty much copied the idea from Finn's design:
He hasn't been having any major problems with these sorts of manifolds and he has built several fast turbo Datsuns with similar manifold.
Sunny
1200 turbo project
The only reason why I did not use steam pipe bends that they were much more expensive than J-pipes for building exhaust manifold. I might build some kind of support for the manifold... It might look brittle on the photo but it is quite sturdy. Well, we gonna see how its going to be when it gets hot.
Is this stainless?
No, that is just regular steel.
