Main : Members : reuby_tuesday T50 conversion clutch cable bush
[<   Previous  1  2  3  4  5  6  7  Next   >]
T50 conversion clutch cable bushPopular
Submitterreuby_tuesdayMore Photos from reuby_tuesday   Last Update2008/4/17 13:57    Tell a friendTell a friend
Hits3378  Comments7    0.00 (0 votes)0.00 (0 votes)
This bush sits in the Dellow converison kit belhousing  a14/15 to T50 box
pepper
Posted: 2008/4/18 4:37  Updated: 2008/4/18 4:37
 Re: T50 conversion clutch cable bush
isnt it the bush to put in the center of the flywheel??
reuby_tuesday
Posted: 2008/4/18 6:16  Updated: 2008/4/18 6:16
outer diameter
25.16mm or .990 of an inch
inner diameter
11.99mm or 0.472 of an inch
Ahhh dont say that Im getting nervous that I have it all wrong...
I think a call to dellow is the go.....
pepper
Posted: 2008/4/18 6:32  Updated: 2008/4/18 6:32
i think its what they call, 'sintered brass bush'
from memory you need to soak it through with oil before installing.
dattoman_1000
Posted: 2008/4/18 10:36  Updated: 2008/4/18 10:36
Thats the spigot bush that goes in the flywheel to support the input shaft
I use a roller bearing in mine instead
Dundee1000
Posted: 2008/4/18 12:41  Updated: 2008/4/18 12:41
is the Dattoman back home???
if it's a sintered bearing, fill it up with oil, then SQUEEZE the oil into it till u can see it "beeding" on the outside of the bush...
74B210
Posted: 2008/4/18 16:12  Updated: 2008/4/18 16:12
Not too shy to talk
if it is a pilot bushing for in the crank to support the front of the input shaft for the trans, get some 20W50 or gear oil. take a propane torch, put the oil and bushing in a metal container and start slowly heating it up.
But do be careful as the oil will catch fire, use something where you can heat the metal container from the bottom, and STOP just after it starts boiling! let it cool, wipe off and install!
(i work in a transmission shop....this is how i do that)
