[< Previous 213 214 215 216 217 218 219 Next >]
Rear Disks B140
3Rotor 2008/4/19 14:52 Tell a friend
2069 2 0.00 (0 votes)
| profiles for the brackets to fit Maxima rear calipers onto the diff of a B140 Ute |
| Poster |
Thread |
| 3Rotor |
Posted: 2008/4/19 14:59 Updated: 2008/4/19 14:59 |
Home away from home   Joined: 2006/6/3 From: South Africa Posts: 281 |
 Re: Rear Disks B140 Disk size is 240mm. offset is attained by making 2 bushings, which bolts to the caliper, that slide through the big holes, when all is line up and the caliper brace does not touch the disk, these 2 bushings get welded to the bracket,
Disk perimeter clearance is about 1.6mm
I've installed this on mine, along with the Caravel front disks, so far, brake balance seem to be as close to neutral as can be...
which is a bit weird actually....
