Main : Mechanical : Brakes subaru discs and calipers
[<   Previous  299  300  301  302  303  304  305
subaru discs and calipersPopular
Submitterrally-a-coupeMore Photos from rally-a-coupe   Last Update2002/7/4 6:30    Tell a friendTell a friend
Hits8800  Comments11    0.00 (0 votes)0.00 (0 votes)
subaru discs and calipers on standard struts
Datopower
Posted: 2002/11/5 19:54  Updated: 2002/11/5 19:54
 Re: subaru discs and calipers
I'd really like to know how this conversion happens...those vents looks beautiful... any help regarding this setup??
So the struts are off a sub? So these bolt straight in ?
Cheers
1200rallycar
Posted: 2002/11/6 1:52  Updated: 2002/11/6 1:52
im under the impression that these struts arnt actually in rally-a-coupe's 1200 yet, hes just got them waiting and hes going to try and figure out how to put em in later, im thinking it would be easier to modify discs/calipers to fit rather than entire strut, do these fit in 13's i hink they do actually but confirmation would be good!
GT
Posted: 2002/11/5 15:53  Updated: 2002/11/5 15:53
hey man u gotta post that conversion plez because i am need of some serouis stopping power urgently GT
dimlight65
Posted: 2002/7/5 15:24  Updated: 2002/7/5 15:24
Whoa Nellie! Post a description of this conversion, please! What Scooby Doo is used as the donor? What sre the struts? Help me out here!
rally-a-coupe
Posted: 2002/7/5 22:57  Updated: 2002/7/5 22:57
they are standard struts i dont know what model subaru they are off i brought them for $20 each but i can find out what they are
Datopower
Posted: 2002/11/13 19:57  Updated: 2002/11/13 19:57
Hey rally-a-coupe !
Any luck with finding what model sub' these are off ? What's involved with this conversion??
Cheers
rally-a-coupe
Posted: 2002/11/14 7:08  Updated: 2002/11/14 7:08
ill try
1200rallycar
Posted: 2002/11/14 8:10  Updated: 2002/11/14 8:10
my mates old man was talking to me about brakes off an "early 80's model subaru" once, probably same thing, if that helps?
Posted: 2013/4/3 8:40  Updated: 2013/4/3 8:49
Early 80s would probably be the Subaru Leone/DL/GL, but they are only 230 mm rotors. The B310 Sunny (and A10 Stanza/510) rotors are 245mm. Leone came with either solid or ventilated. With a 44 mm height about 7mm will need to be machined off the hub-mating face of the rotor (they are 15mm thick there, while S13 & B210 faces are only 8mm thick).
Being small, they might fit under 12" alloy wheels???
The mid-to-late 80s Leone series II (1985-1991) had 242mm ventilated rotors. They are still not big, but they are ventilated. With a 51.9 height I doubt these are the ones in the photo.
They come with the same 70mm centering hole as B110, with 90mm bolt circle instead of B110's 87mm (both Subaru and B110 use M10 holes).
And they are cut out in the center for weight reduction, which is always good.
Datopower
Posted: 2002/11/14 20:07  Updated: 2002/11/14 20:07
Cheers for that rally-a-coupe, i look foward to finindg out..
rally-a-coupe
Posted: 2002/11/6 4:52  Updated: 2002/11/6 4:52
the strut are std 1200 and some one has made an adaptation plate for the caliper no these arnt going in my car yet i have a set of sunny struts and discs
