Main : Mechanical : Drive Train Getrag 5-Speed Transmission
[<   Previous  581  582  583  584  585  586  587  Next   >]
Getrag 5-Speed TransmissionPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2008/4/21 6:09    Tell a friendTell a friend
Hits2385  Comments3    0.00 (0 votes)0.00 (0 votes)
Phil Morton's rally Coupe
lukeADE
Posted: 2008/5/13 8:03  Updated: 2008/5/13 8:03
 Re: Getrag 5-Speed Transmission
Any idea which Getrag 5-speed this is?
Being a BMW freak as well as a 1200 freak, I have a couple of Getrag 260 5 speeds in the shed from e30 2.5L engines... the boxes are fairly compact, and have a remote shifter, so you could almost make the linkage as long or as short as you like so move the position of the shifter around. They also have a very sweet shift, much better than the old 56 in the 1200 ... and Z3 / Z4 short shifters are a direct fit also!
If someone was to make up adapter plates for these, they would be an excellent box behind the a-series, and they are readily available from the wreckers these days.
datokid
Posted: 2009/2/16 13:03  Updated: 2009/2/16 13:03
wow for a race car its pretty flash
Posted: 2017/1/15 6:19  Updated: 2017/1/15 6:21
"Phil [made] a custom bell-housing from and old A series casing which allowed fitment of a very strong Getrag gearbox. This has close ratios as well as a direct drive 5th gear."
This suggest it is a Getrag 250, 262, etc. (non-overdrive). The photo looks like a 260/262 - separate bolts for the bellhousing. But maybe it's a non-Bimmmer Getrag
Photo shows the Getrag gearbox, an adapter plate and part of front case for A-series gearbox
