Main : Misc 4age for my 1000 ute
[<   Previous  1477  1478  1479  1480  1481  1482  1483  Next   >]
4age for my 1000 utePopular
SubmitterdodgerMore Photos from dodger   Last Update2008/5/14 1:24    Tell a friendTell a friend
Hits2920  Comments12    0.00 (0 votes)0.00 (0 votes)
Bought a 4age engine for my 1000 ute project on Monday. Looks like it will be pretty easy to fit.
ZigZag
Posted: 2008/6/14 13:42  Updated: 2008/6/14 13:42
 Re: 4age for my 1000 ute
i want one of those lol
dodger
Posted: 2008/5/15 23:59  Updated: 2008/5/15 23:59
Not too shy to talk
Thanks so much for your help! I gess i will have to reduce that gallery Ill try 3.5mm first. Im not one for trying to scream the brains out of a engine but im sure once those carbs open up and the induction noise gets to me. I may hold 1st 2nd 3rd etc for a bit longer than I should have ha ha
Tyrie
Posted: 2008/5/16 0:49  Updated: 2008/5/16 0:49
Yep good idea, Its scary how quickly it can dump all its oil out the breathers.
mradtee23
Posted: 2008/5/16 8:03  Updated: 2008/5/16 8:03
Also it seems as if you have the RWD engine here, they were the only ones that had that long water inlet neck on the head, FWD variants have a short stumpy one that comes out at a much sharper angle. Unless you changed it for that item
ineed one of these rwd water pipes for mine at the moment! any one know have one or know where to pick one up?
mines in a 1200 ute though
kululadotgroen
Posted: 2008/5/16 8:15  Updated: 2008/5/16 8:15
You might be able to buy the housing from some spares shops. Ask for the 4AC waterpump housing. It's cheaper, but exactly the same as the RWD 4AGE ones(which are very scarce and might not even be available in the shops). The 4AGE pump then bolts onto the 4AC housing, which bolts onto the 4AGE block. Don't try to use the 4AC pump though, as it's neck is longer than the 4AGE ones, and the pulleys don't line up as a result.
Some of the 4AGE pumps have slightly higher impeller blades, and sometimes they foul on the 4AC housing as a result. You simply file them down until the pump turns freely, and you're set.
mradtee23
Posted: 2008/6/14 12:58  Updated: 2008/6/14 12:58
awesome info, thanks mate.
dodger
Posted: 2008/5/15 6:04  Updated: 2008/5/15 6:04
Not too shy to talk
Carb to master cyl is a bit dodgie but if thats the biggest problem I have Im laughing hey. The Dizzy is out the side, LH side front of the head.
Yeh there is plenty of room for superchargers, turbos etc later on down the track .
The engine is a rear wheel drive version out of a 83 sprinter. Cant wait to hear it purr with those twins on it.
kululadotgroen
Posted: 2008/5/15 14:29  Updated: 2008/5/15 14:29
Cool, so 90% of you piping trouble is solved for the cooling system. Only thing about those engines is that their blocks aren't as strong as the later ones from 88 onwards, they don't have the same amount of strenthening ribs. You don't have to worry to much about that though, they are still tough as nails.
Also their big-ends and gudgeons are 2mm smaller than the latter models. That being 40mm and 18mm vs. 42mm and 20mm.
If you are going to open the motor up, do yourself a favour, and install a restrictor in the oil gallery that feeds oil to the head. Sometimes if you drive them at high revs for extended periods of time, they tend to fill the cam covers up with oil, and you might end up getting oil starvation. The hole is towards the front of the block under where the dizzy sits, and is 6mm. You can take it down to 3.5mm, and for extreme race conditions I have heard of people bringing it down as far as 1.5mm. Drill and tap the hole to take a grubscrew, which has been drilled out to the desired size.
Luckily the later model engines have exactly the same mounting holes and stuff, so if you want to change to one of them later, it's simply a bolt in change. All the parts are interchangeable, with the exception of the conrods and crank which has to match.
3Rotor
Posted: 2008/5/14 8:13  Updated: 2008/5/14 8:13
is the distributor on the side, or at the back?
if it's at the back, it might be a bit tight, but not a major problem.... I usually just remove them anyhow, and run 60-2, much nicer...
kululadotgroen
Posted: 2008/5/14 9:22  Updated: 2008/5/14 9:22
3Rotor, as far as I know, have seen, and have researched, none of the 16V 4AGE's has dizzys at the back of the head. They al sit on the zorst side, above the number one zorst port, if it has a dizzy that is. The only variation to this is where there might be a coilpack bolted to the rear of the head. Only the 20V's has the dizzy at the back of the head.
I think the fitment will be even easier to the 1000 than to the 1200. You don't have the strut towers to contend with for space, and there seems to be lots of space on the zorst side for a nice flowing turbo manifold...
Also it seems as if you have the RWD engine here, they were the only ones that had that long water inlet neck on the head, FWD variants have a short stumpy one that comes out at a much sharper angle. Unless you changed it for that item. Make sure you get the RWD waterpump too, it makes the plumbing much easier. On the RWD pump housing, the thermostat is contained in the housing, where as the FWD has a sepperate housing that bolts onto the engine holding the thermostat.
Tyrie
Posted: 2008/5/14 10:13  Updated: 2008/5/14 10:13
how is the carb to brake master clearance? And pity the outlet for your radiator is on the wrong side now.
