Main : Misc : Forum 25mm front swaybar
[<   Previous  135  136  137  138  139  140  141  Next   >]
25mm front swaybar
25mm front swaybarPopular
SubmitterDavemanMore Photos from Daveman   Last Update2008/6/15 11:06    Tell a friendTell a friend
Hits1641  Comments8    0.00 (0 votes)0.00 (0 votes)
L18_B110
Posted: 2008/6/16 5:25  Updated: 2008/6/16 5:25
 Re: 25mm front swaybar
25mm? fark that's big! That's 3.2 times the roll stiffness of the standard bar, and as good as double the roll stiffness of a 20mm 120Y bar.
looks to be hanging very low too - pls tell me the suspension is not at full droop there?
do you know what spring rate you've got?
Daveman
Posted: 2008/6/16 8:23  Updated: 2008/6/16 8:23
You can just make it out but it's not actually attached to the LCA's yet. It actually gives me more clearance than the old swaybar( which I must add was horrible). I can now get my jack under the crossmember from the front!
I've got some 225lb springs and some 250's. It does seem like overkill but the old datsun suspension manual reckons they should be even thicker! - I also happened to have this swaybar sitting around in the garage so the experiment sort of turned into the final product.
benny
Posted: 2008/6/16 8:29  Updated: 2008/6/16 8:29
The manual wasn't referring to hollow tubing by chance was it? 25mm does seem mighty thick.
I run a 22mm bar and that may be a bit to stiff.
L18_B110
Posted: 2008/6/16 8:35  Updated: 2008/6/16 8:35
I think the cars in the old competition suspension manual may have been restricted to using standard or optional coils. your coils will be at least double what they were running.
although there is a bit of a trend towards a soft spring, big sway bar setup returning in touring cars, but you need specialised shock valving to really do it properly.
Daveman
Posted: 2008/6/16 8:53  Updated: 2008/6/16 8:53
They definitely specify a 1 inch solid bar of stressproof steel. I have a feeling they were using Z car rear springs which are probably around the 150lb mark.
Mine isn't a very efficient design shape so won't be as rigid in torsion than the standard bar shape.
People forget that the shape influences its performance, not just the bar thickness.
L18_B110
Posted: 2008/6/17 0:48  Updated: 2008/6/17 0:48
the comp manual says they used 110lb/in front springs.
LAGWAGON
Posted: 2008/6/17 4:58  Updated: 2008/6/17 4:58
i use a 25mm front bar on the front of my 1600. although non adjustable it seems about right for my setup. i also run a rear bar which many people say is unnecessary but i have found it to help.
the car did seem to have plenty of body roll issues in your pics so playing with stiffer swaybars would seem a logical step. i have found a lot of improvement in the cars corner speed as well as powering out of corners can be found in fine tuning swaybars. good luck
