Main : Misc : Forum 20mm rear swaybar
[<   Previous  133  134  135  136  137  138  139  Next   >]
20mm rear swaybar
20mm rear swaybarPopular
SubmitterDavemanMore Photos from Daveman   Last Update2008/6/15 11:08    Tell a friendTell a friend
Hits2454  Comments10    0.00 (0 votes)0.00 (0 votes)
Anonymous
Posted: 2009/9/22 11:36  Updated: 2009/9/22 11:36
 Re: 20mm rear swaybar
sitting under my sedan now, and even wit stuffed shocks, makes the rear sit flat - used to feel like it wanted to trip over the front of the car under hard cornering, almost like the rear wanted to roll over to opposite front corner- not now!, now just need time for installing the new shocks
cheater_5
Posted: 2008/6/16 3:49  Updated: 2008/6/16 3:49
another pic:
and a 25mm front...... dang
kululadotgroen
Posted: 2008/6/15 21:11  Updated: 2008/6/15 21:11
I thought that a sway bar had to be atatched to the body somewhere, and then to the axle it's trying to "anti-sway"...
Tyrie
Posted: 2008/6/16 0:51  Updated: 2008/6/16 0:51
I cant really see from the pic but I assume its clamped to the spring? That is how it is described in the nissan competition leaflet/book that was posted on here a while ago.
Do you think that 20mm will turn it into an oversteer pig? Seems awefully big...?
nsr500
Posted: 2008/6/16 3:56  Updated: 2008/6/16 3:56
Quite a regular
From what I can see, the sway bar will have little to no effect, it needs to be attched to the chassis somewhere.
It looks to be mounted too far back on the spring?
Let us know how it works.
Tyrie
Posted: 2008/6/16 4:49  Updated: 2008/6/16 4:49
I think being that close to the end of the spring it functionally IS attached to the chassis, no?
L18_B110
Posted: 2008/6/16 5:18  Updated: 2008/6/16 5:18
ordinarily a 20mm bar would be excessively large for the rear, but that setup will be less effective than if mounted to the chassis, so you might get away with it.
looks a bit close to the chassis rail too - have you checked for bind at full travel? if it happens while you're driving, you'd want to have lightning reflexes and excellent car control skills.
LSDWAGON
Posted: 2008/6/16 5:55  Updated: 2008/6/16 5:55
Quite a regular
What car is the bar off?
Daveman
Posted: 2008/6/16 8:18  Updated: 2008/6/16 8:18
L18 - clearance is fine. I know people say it a lot but the picture makes it look closer than it really is. Also that position only moves less than half the travel of the diff still alowing around 5-6 inches of travel.
If there are issues with it bottoming out it will actually mount to the underside of the spring by swapping sides with the brackets. The only reason it's where it is was because the bar fouls the diff housing when swung down that far. It could be resolved by spacing it off the diff housing further though.
I'm not claiming any brilliance with this design but I'm betting it won't be completely useless and I just worked with what I had.
