Main : Members : ddgonzal Road Fix for Muffler
[<   Previous  195  196  197  198  199  200  201  Next   >]
Road Fix for MufflerPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2008/6/26 5:55    Tell a friendTell a friend
Hits2156  Comments8    0.00 (0 votes)0.00 (0 votes)
Zip Ties -- the new duct tape
Curtis
Posted: 2008/6/26 11:45  Updated: 2008/6/26 11:45
 Re: Road Fix for Muffler
lol reminds me of when i once join two bits of exhust pipe together with one of those muffler wrap bandages and then zip ties round the bandage lol i got meltin plastic fumes for like a week, the join held for a month
revhead001
Posted: 2008/6/26 12:09  Updated: 2008/6/26 12:09
It is a bit of a worry when the Moderator of a Datsun forum's idea of a toolkit is 5 different sizes of Zip Ties. You crazy Americans crack me up!
3Rotor
Posted: 2008/6/26 13:56  Updated: 2008/6/26 13:56
lest we not forget... zip-ties can be traced back straight to the space shuttle program.... so it's by no means low-tech... as matter of fact it's as high tech as you can get, along with ducktape and a couple of other things....
mr_nismo4
Posted: 2008/6/26 14:09  Updated: 2008/6/26 14:09
If it's tight and it shouldn't be, use WD-40. If it's loose and it shouldn't be, use gaffa tape (in your case DD, zip ties). For all other problems use a hammer and if that doesn't work you've got an electrical problem
kululadotgroen
Posted: 2008/6/26 9:58  Updated: 2008/6/26 9:58
Well I suppose if the only function of the ties are to keep it on the bolt sticking out, then there is no reason why they shouldn't last for some time. It would be a bit more dodgy if the zorst was only hanging from the ties though...
We fitted a Leyland bus' radiator cap to our A14 powered Mazda bakkie once, on the way to the fishing waters. It was eventually sold still with the Leyland cap on there...
WhiteSedan
Posted: 2008/6/26 10:02  Updated: 2008/6/26 10:02
LOL!
These are those things that your just not meant to tell anyone about DD.
I would of just borrowed an m8 nut from the strut top, surely you took some spanners with you!
scotty01
Posted: 2008/6/26 11:36  Updated: 2008/6/26 11:36
lol zip ties, good for any application
