Main : Mechanical : Drive Train IPRA Coupe Gearbox X-member
[<   Previous  542  543  544  545  546  547  548  Next   >]
IPRA Coupe Gearbox X-memberPopular
SubmittersikyneMore Photos from sikyne   Last Update2008/7/13 8:28    Tell a friendTell a friend
Hits2436  Comments6    0.00 (0 votes)0.00 (0 votes)
X-member i had to make because the engine is on an angle.
Dodgeman
Posted: 2008/7/14 4:20  Updated: 2008/7/14 4:20
 Re: IPRA Coupe Gearbox X-member
In the original car, the bolts that secure the mount to the chassis/body bore a vertical load only. In this design there is a substantial bending moment on them & it's a force that this chassis mounting point, & the small fasteners was never designed to take.
To secure it properly it would benefit from another two legs running across from the actual mounting point, or even running slightly forward & attaching to the underfloor area.
sikyne
Posted: 2008/7/14 5:40  Updated: 2008/7/14 5:40
Hi Dodgeman, The gearbox mounts and engine mounts are both solid mounted except for a 5mml thick nylon washer on both.
I Think i can see what you are saying? But with the engine mount solid the load should only be vertical and tortional as long as the engine mounts prevent for and aft movement?
I might put the nylon washers on the body side of the X-member and have it bolted flat to the gearbox.
On this gearbox there is an additional X-member flange on the rear of the extention housing which i could tie in aswell. You have got me thinking..
Thanks
Edit: Yes, what you are saying makes sense now. I might to have to do something about it.
frankthedolphintrainer
Posted: 2008/7/13 11:34  Updated: 2008/7/13 11:34
fuk that is sexy
ratsun_a14
Posted: 2008/7/13 12:48  Updated: 2008/7/13 12:48
why is it on such an angle?
hotrocket
Posted: 2008/11/17 0:48  Updated: 2008/11/17 0:48
ask booka (Dodgeman) he'll tell ya
