[< Previous 2747 2748 2749 2750 2751 2752 2753 Next >]
| Poster |
Thread |
| jaimecidpedro |
Posted: 2003/6/28 6:18 Updated: 2003/6/28 6:18 |
No life (a.k.a. DattoMaster)   Joined: 2001/8/2 From: Posts: 1354 |
 Re: nutcasses 120y drop another angle Hy bro. What procedure did you follow to drop it. Blocks? decambering rear leaves? .Front, cut spring? Looks good. I just went to the junk yard and got 2 stock steel wheels (Datsun 13") and took them to my buddies at" Taylor Made Wheels" for stretching. I will make them 9 inch wide, will try them in the rear. Want to experiment once more. Later I will make 13X10's , once I get the appropiate tires for those "dices"(10's).I got to figure how to bring in those tires from NZ. Jaime._______________________
| Poster |
Thread |
| nutcase |
Posted: 2003/6/28 9:49 Updated: 2003/6/28 9:49 |
Just can't stay away   Joined: 2002/11/15 From: Charlotte NC USA Posts: 134 |
 Re: nutcasses 120y drop another angle I used 2" blocks in the back but you have to remove 1/2" of metal and rubber to install them so you only get 1.5" and for the front I am using 240z rear springs cut 3 coils to get 1.5" lower than stock and strong enough to hold up the L motor
