Main : Mechanical : Engine Engine Weight Chart
[<   Previous  1941  1942  1943  1944  1945  1946  1947  Next   >]
Engine Weight Chart
Engine Weight ChartPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2008/8/31 19:46    Tell a friendTell a friend
Hits8834  Comments8    0.00 (0 votes)0.00 (0 votes)
From data in Datsun1200.com wiki
D
Posted: 2011/4/22 5:13  Updated: 2011/4/22 5:17
From: under the Firmament LOL no twiglight effect BS
 Re: Engine Weight Chart
Id say one clean notch below the a12 even though the twin cam head
is much heavier than the pushy head.
Most alloy blocks are almost halve the weight of the cast iron ones.
The ca18de bare block is about 37kg while a Renault J series 2.2 liter
bare block (I collected one time for a 1000 option) was 22kg.
I wonder what an L series block weighs bare?
The ca18et with heavier turbo setup is on par with stock l18 while
the ca18s is supposedly 9-12 kg lighter. The ca head is 16kg and I
think the L18 head is 2-3kg lighter.
revhead001
Posted: 2011/4/21 11:52  Updated: 2011/4/21 11:52
I wonder where the CR14DE fits in on this chart... Hmmmmm.
Dodgeman
Posted: 2008/9/1 2:52  Updated: 2008/9/1 2:52
Why, ... I wonder, does the Buick 3.5L show as weighing less than the Rover 3500 V8 when to all intents & purposes they are the same engine.
perthute
Posted: 2008/9/1 3:04  Updated: 2008/9/1 3:04
is the sr20det weight with aircon power steering ect ect
has you can take a lot of weight off em when there going in dattos
Posted: 2008/9/1 3:41  Updated: 2008/9/1 3:41
Engines are usually weighed without A/C pump and power steering pump. But who knows, these weights are collected from various sources. Details: datsun1200.com article Engine Weights article.
Why ... does the Buick 3.5L show as weighing less than the Rover 3500 V8
Because BMC/Rover re-engineered the block to made it more reliable for heavy-duty use. Now it is considerably heavier than the original Buick design. Read the details here: Wikipedia: Rover V8 Engine
WhiteSedan
Posted: 2008/9/1 9:26  Updated: 2008/9/1 9:26
I can verify a couple of weights in the next few weeks, I have an L16 bare to put back in the racecar and I am weighing everything to see how where all the weight is going as I am building the car up.
Also have a few L18/L20's, 2 A12's, a A14 and an A15 laid around.
There looks to be quite a few odd weights on that chart.
DatsAndy
Posted: 2008/9/1 9:44  Updated: 2008/9/1 9:44
Is there a 3.5 Litre Buick V8 i know the VN etc commodore engines are a trumped up Buick V6 and its 3.8. The Rover 3500 V8 is Alloy From memory. So would it way more than the mystery buick 3.5 V8 ?
Posted: 2008/9/5 5:08  Updated: 2008/9/5 5:08
Yes, the 3.5 engine was originally made by GM and was an all alloy V8. GM even sold a turbocharged version in 1962!
Then GM sold it to Rover -- and Rover made it heavier. Rover made 3.5 and larger sizes up to 4.0 liter.
The more common Buick 3.8 is a V6 (not V8) and is an iron block, a different design but based on the V8 design. The Buick V6 is a good engine in its own right with one of the best 2-valve port designs ever.
