Main : Members : WhiteSedan L16 1200 inside
[<   Previous  31  32  33  34  35  36  37  Next   >]
L16 1200 inside
L16 1200 insidePopular
SubmitterWhiteSedanMore Photos from WhiteSedan   Last Update2008/9/4 11:11    Tell a friendTell a friend
Hits2402  Comments13    0.00 (0 votes)0.00 (0 votes)
Getting there slowly.
iDatto
Posted: 2009/8/11 7:44  Updated: 2009/8/11 7:44
 Re: L16 1200 inside
this things mint
WhiteSedan
Posted: 2008/9/8 8:21  Updated: 2008/9/8 8:21
 Re: L16 1200 inside
10points goes to Daveman, I have fibreglass guards and apron to use, both a steel and fibre set will be painted as well as a spare steel bonnet and bootlid.
dat141
Posted: 2008/9/8 10:17  Updated: 2008/9/8 10:17
 Re: L16 1200 inside
Looks so schmick Sean, makes me wish I had painted the whole shell bare rather than just masking everything up. Go the sedans
cheater_5
Posted: 2008/9/4 22:06  Updated: 2008/9/4 22:06
 Re: L16 1200 inside
mmm that is clean.
Running flares on the rear i see?
Does the standard dash fit with the cage in or you going to make or have made a new one?
Keep it up
Ianey
Posted: 2008/9/4 23:38  Updated: 2008/9/4 23:38
 Re: L16 1200 inside
Hey Sean,
That looks bloody terrific mate.
Did you scrape all that sound deadener stuff off?
Also, are you not running an under dash bar?
Cheers, Ian
PIGDOG
Posted: 2008/9/5 4:18  Updated: 2008/9/5 4:18
 Re: L16 1200 inside
think he was waiting for the dash and pedal box to be done before the under dash bar gets put in....pretty sure i remember him saying that
WhiteSedan
Posted: 2008/9/5 8:22  Updated: 2008/9/5 8:22
 Re: L16 1200 inside
Cheers for the kind words everyone, I was really worth all that sanding, makes it look so much smoother, and sound deadening is easy to get off when its -3deg at early hours of the morning, it gets really brittle. Cars getting pretty close now, have finished wiring, started brake lines and puting brake system back in.
Francois the colour is just a five digit number with a letter in front unfortunately, sort of light blue/grey in the sun.
The car has no underdash bar yet, Pigdogs right I was getting the pedalbox sorted then welding the bar in but I've run out of time, car needs to be finished by end of october, that will have to come when the new motor goes in end of next year.
I think I'll also add a diagonal on the roof and a couple in the rear to stiffen things up and make it a bit safer, also add another intrusion bar next to my seat and make some better seat mounts and probably turret the rear shock mounts for coilovers with a single locating leaf and tramp rod.
Dash has been cut to fit around the cage, the metal part has to slide in through front window bolt up, then the pad screws to that from inside the car. But brake lines and pedal box needs to go in before that.
Cheater, yep flares, with 13inch superlights!
Too much to do, not enough time!!
10 points if anyone notices my effort in shedding a few kg's to compensate for the heavier motor.
Daveman
Posted: 2008/9/5 9:37  Updated: 2008/9/5 9:37
 Re: L16 1200 inside
hmmm are those fibreglass guards??/
EDIT: I can see the weight saving now, you ditched your brake mc!
kululadotgroen
Posted: 2008/9/4 14:10  Updated: 2008/9/4 14:10
 Re: L16 1200 inside
Nice colour... What's it called?
Burke_a_lot
Posted: 2008/9/4 11:48  Updated: 2008/9/4 11:48
 Re: L16 1200 inside
Wow! Great job on the paint!
baldy
Posted: 2008/9/4 11:39  Updated: 2008/9/4 11:39
 Re: L16 1200 inside
That is a better paint job on the inside of your car sean than i have seen on some cars out side. looks good mate.
TUF-110
Posted: 2008/9/4 21:35  Updated: 2008/9/4 21:35
 Re: L16 1200 inside
Looks clean Sean well done mate, Good to see some progress on the old girl.
Jake
