[< Previous 2683 2684 2685 2686 2687 2688 2689 Next >]
| Poster |
Thread |
| feral |
Posted: 2003/7/12 23:19 Updated: 2003/7/12 23:19 |
Home away from home   Joined: 2002/5/1 From: Millgrove Vic OZ Posts: 985 |
 Re: JTS A15 Twin 45s What size chokes in the 45's ?
| Poster |
Thread |
| stevo1000 |
Posted: 2003/7/12 23:48 Updated: 2003/7/12 23:48 |
Just can't stay away   Joined: 2003/1/16 From: Melbourne. Vic Posts: 133 |
 Re: JTS A15 Twin 45s Sorry Erroll....NFI, I'll ask the head Mechanic............Cam cheers stevo
| Poster |
Thread |
| AFRacer |
Posted: 2003/7/13 1:44 Updated: 2003/7/13 1:44 |
Home away from home   Joined: 2002/3/7 From: Little Rock, AR Posts: 639 |
 Re: JTS A15 Twin 45s So how much power is this one putting out? I see all the external parts are described, what about internals??? Whoever owns this car should throw in a $20 inline fuel pressure guage so you know what your fuel pressure is. Through net searching, I found that anywhere from 1.5-3.9 psi was okay w/Dellorto/weber carbs....however not ideal. I ran at 3.0 for a while...ran great...just a tad rich on the A/F guage. I did a slight rejetting on the idle jets and turned the fuel pressure down to 2.5 psi, and it ran like a bat out of hell! A/F guage never went too rich or too lean. ....Tuning can sure be rewarding sometimes!
| Poster |
Thread |
| dattoman_1000 |
Posted: 2003/7/14 11:57 Updated: 2003/7/14 11:57 |
No life (a.k.a. DattoMaster)   Joined: 2002/8/11 From: Perth Posts: 2692 |
 Re: JTS A15 Twin 45s I don't suppose you could get more pics of the oil coller piping from the pump /? And also measure the diameter of the underdrive pulley and the crank pulley for me ?
| Poster |
Thread |
| D |
Posted: 2003/7/15 2:05 Updated: 2003/7/15 2:05 |
No life (a.k.a. DattoMaster)   Joined: 2002/10/28 From: under the Firmament LOL no twiglight effect BS Posts: 10994 |
 Re: JTS A15 Twin 45s What happened to the carb softmounts?? Ive seen these type of setups without softmounts before but Im sure they cause vaccum probs no?
| Poster |
Thread |
| feral |
Posted: 2003/7/15 2:21 Updated: 2003/7/15 2:21 |
 Re: JTS A15 Twin 45s D, They are soft mounts, but the aluminium bodied ones. These are much more reliable than the O ring type.
My sunny sneezed once and blew the softened nitrile O ring out. It took me ages to find the air leak as it blew out on the bottom side where you couldnt see even using a mirror.
