Main : Mechanical : Brakes Rear disk conversion for a Ute
[<   Previous  186  187  188  189  190  191  192  Next   >]
Rear disk conversion for a UtePopular
Submitter3RotorMore Photos from 3Rotor   Last Update2008/11/28 17:54    Tell a friendTell a friend
Hits2284  Comments3    0.00 (0 votes)0.00 (0 votes)
some shots of a conversion I'm doing for a guy.....
3Rotor
Posted: 2008/11/30 6:32  Updated: 2008/11/30 6:32
 Re: Rear disk conversion for a Ute
as far as i know, yes a std Ute diff (nissan1400 bakkie, 1984, ZA)
here is the particulars that should give you the info as to whether it will work for you or not...
it's made from 12mm gauge mild-steel, the adjuster stubs are retained in place after caliper spacing, with 2 M6 nuts on ether side.... it still uses the OEM bolts for attaching the caliper, as well as to the diff itself.
steveo
Posted: 2008/11/29 1:55  Updated: 2008/11/29 1:55
what diff is that? is it a ute diff?
