Main : Misc spot the difference
[<   Previous  629  630  631  632  633  634  635  Next   >]
spot the difference
spot the differencePopular
SubmitterA14forceMore Photos from A14force   Last Update2008/12/7 5:42    Tell a friendTell a friend
Hits2031  Comments6    0.00 (0 votes)0.00 (0 votes)
That grey colouring isn't from running leaded gas.
A14force
Posted: 2009/3/27 20:56  Updated: 2009/3/27 20:56
 Re: spot the difference
the speckled colouring you can see is aluminium from the melted piston.
Posted: 2009/3/27 21:26  Updated: 2009/3/27 21:26
Is that true? Maybe it is metal from the head gasket -- it appears to have blown between the two cylinders, judging by the black mark between them.
The right cylinder is dark, black and moist looking. Definitely not a normal burning color.
frankthedolphintrainer
Posted: 2009/3/27 23:48  Updated: 2009/3/27 23:48
i would think thatits blown the gasket also but i would also say that the wet area would just be oil from the galleries
LittleFireyOne
Posted: 2009/3/28 2:03  Updated: 2009/3/28 2:03
Kinda looks like the valves on the bad side are seated a little lower?
steveo
Posted: 2009/3/28 10:41  Updated: 2009/3/28 10:41
you did a good job of it bart!
