Main : Misc Gearbox mounting
[<   Previous  617  618  619  620  621  622  623  Next   >]
Gearbox mounting
Gearbox mountingPopular
SubmitterAsblikMore Photos from Asblik   Last Update2008/12/11 4:36    Tell a friendTell a friend
Hits2477  Comments3    0.00 (0 votes)0.00 (0 votes)
The top bracket is for the 5 speed gearbox using the same mounting holes. The bottom bracket is for the std 4 speed gearbox
Posted: 2015/6/18 23:26  Updated: 2015/6/18 23:28
 Re: Gearbox mounting
Looks like 1400 mounts for a 60A 5-speed and 60L 4-speed? If so the dished bracket will also fit the 60L 5-speed.
Here's the equivalent versions from B310:
datsunbeginner
Posted: 2015/6/19 5:13  Updated: 2015/6/19 5:13
What do you do when someone has lobbed off the factory mounting points on the transmission tunnel (like they did on my ute)?
Posted: 2015/6/19 8:06  Updated: 2015/6/19 8:07
You can cut the spotwelds off mounts on a donor sedan/coupe, and transfer them to your ute. This is a fortuituous opportunity to improve the mounts. They can be fitted in the original 1200-gearbox location but they interfere with the 60-series reverse lamp. Note that they can be used moved back to suit the 60-series (1400) gearbox.
or you can fit a typical swap crossmember
