Main : Members : PIGDOG clutch master clearance
[<   Previous  21  22  23  24  25  26  27  Next   >]
clutch master clearancePopular
SubmitterPIGDOGMore Photos from PIGDOG   Last Update2009/2/16 4:38    Tell a friendTell a friend
Hits1876  Comments8    0.00 (0 votes)0.00 (0 votes)
test fitted a toyota master cylinder in place of the 200b one, heaps more clearance than before. but decided on putting in under the dash instead and running a remote res. new master only cost $25 with was pretty good
DatsAndy
Posted: 2009/2/17 1:21  Updated: 2009/2/17 1:21
 Re: clutch master clearance
Or you could run a hose with connection out of it to the fluid cup and have a similar bracket to the ones that hold your fuel filter over in the corner of the engine bay.
Edit: Looking good. Is all that plenum and rail stock or custom made ?
PIGDOG
Posted: 2009/2/17 1:25  Updated: 2009/2/17 1:25
its ta22 celica clutch master, part number JB1140
its very easy to make it a remote res setup as it already have a thread tapped into it to hold the stock res on
its a stock plenum with a different cover on the rear for a bit more room, and its had lots of things shaved off it
stock fuel rail also, will slightly modify it so that it suits where my fuel lines are a bit better
hotrocket
Posted: 2009/2/17 1:27  Updated: 2009/2/17 1:27
cheers thanks for that
much in mods to make it fit to the clutch pedal?
DatsAndy
Posted: 2009/2/17 1:34  Updated: 2009/2/17 1:34
Remote res Thats the word not that good with terminology, More of a had to be there sort of fella. So you doin away with the modded 180b pedal setup ?
PIGDOG
Posted: 2009/2/17 4:51  Updated: 2009/2/17 4:51
yeah the old pedal setup is going in mr miks car when it gets L series'd
might take some pics of it while its out of the car
hotrocket
Posted: 2009/2/17 5:43  Updated: 2009/2/17 5:43
yeah that be great
hotrocket
Posted: 2009/2/17 1:16  Updated: 2009/2/17 1:16
ive been looking for sumthing like that by is taking up less room,....what model toyota is it from
