Main : Mechanical : Engine A15 3
[<   Previous  1830  1831  1832  1833  1834  1835  1836  Next   >]
A15 3
A15 3Popular
SubmitterDale91More Photos from Dale91   Last Update2009/2/21 12:40    Tell a friendTell a friend
Hits2608  Comments14    0.00 (0 votes)0.00 (0 votes)
A15 freshly painted block
Posted: 2019/10/23 21:01  Updated: 2019/10/23 21:01
 Re: A15 3
these are the G34 pistons
They are used with closed chamber H89 head and the offset dish allows some measure of quench
Dale91
Posted: 2009/2/21 13:24  Updated: 2009/2/21 13:24
 Re: A15 3
yeah i see what you mean how the dish is offset.
Ratsun_a14: yep the more the dish the lower the compression
Dale91
Posted: 2009/2/21 13:17  Updated: 2009/2/21 13:17
 Re: A15 3
yeah just looked at some other pic of a15's and yeah they r stock, they hav a fair bit of dish for stockies though, i thought they would be flat when we took the head to rebuid it
Mildman
Posted: 2009/2/21 13:19  Updated: 2009/2/21 13:19
 Re: A15 3
My A14 looks like this....your dish seems a little offset - different to mine anyway.
ratsun_a14
Posted: 2009/2/21 13:20  Updated: 2009/2/21 13:20
 Re: A15 3
does the dish lower the compression? what is the compression of the motor with pistons like that?
Mildman
Posted: 2009/2/21 13:26  Updated: 2009/2/21 13:26
 Re: A15 3
Dude these are the pistons fitted to the motor the day it was built at the Nissan factory - the compression of the motor with these pistons is the Nissan specified compression ratio 9.0:1.
These are not special pistons that drop the compression ratio of the engine.
Have you seen a standard Nissan A series with flat pistons before? I never say never - but I've only looked inside 3 and they were all dished to some degree...
clyons8
Posted: 2009/2/21 15:16  Updated: 2009/2/21 15:16
 Re: A15 3
Your standard A10's and GX's have the flats.
Never seen the bigger engines with standard flats.
I have seen the offset recesses before but never on any of my engines.
datto1000wagon
Posted: 2009/2/21 22:03  Updated: 2009/2/21 22:03
 Re: A15 3
chris is on the money
a10's had flatys so did the majority of gx's except some used dished pistons
if you want super low comp then an a10 head would be the goods but its round port (doesnt really matter when its boosted) but some say the round ports are better with angles
Dale91
Posted: 2009/2/21 12:53  Updated: 2009/2/21 12:53
 Re: A15 3
nah just stock i think,
ratsun_a14
Posted: 2009/2/21 12:56  Updated: 2009/2/21 12:56
 Re: A15 3
i've never seen them dished likr that before. What brand r they do u know?
Dale91
Posted: 2009/2/21 12:59  Updated: 2009/2/21 12:59
 Re: A15 3
nah sorry but yeah think they r stock cause i haven't changed em, do you reckon these pistons would go alright with a turbo, i.e. lower enough compression. cause i was thinking of turboin it later on?
ratsun_a14
Posted: 2009/2/21 13:07  Updated: 2009/2/21 13:07
 Re: A15 3
Yeah i reakon they could be decompression pistons becase the standard ones are flat,But i could be wrong. i reakon they would be ideal for a turbo set up
Mildman
Posted: 2009/2/21 13:14  Updated: 2009/2/21 13:14
 Re: A15 3
Dish is pretty stock - I've had dished pistons in 2 A12's (early and late) and an A14 stock - not sure which engine has flat pistons stock....
ratsun_a14
Posted: 2009/2/21 12:52  Updated: 2009/2/21 12:52
 Re: A15 3
llooks awesome!!!
R they decompression pistons?
