Main : Mechanical : Drive Train Shifter Repair Kit
[<   Previous  214  215  216  217  218  219  220  Next   >]
Shifter Repair Kit
Shifter Repair KitPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2014/9/13 22:25    Tell a friendTell a friend
Hits2776  Comments3    0.00 (0 votes)0.00 (0 votes)
the clear bushing always wear out and the shifter flops around. The trans shifter seal and tunnel seal make your 1200 quiet once again. The bottom (white) bushing does not usually wear out.
See Shifter Bushes
datsunbeginner
Posted: 2014/9/10 10:48  Updated: 2014/9/10 10:48
 Re: Shifter Repair Kit
What is the difference between the small boot and the large boot? Were they for different models?
Posted: 2014/9/11 20:30  Updated: 2014/9/11 20:32
Online!
Both are used at the same time on a 1200.
The small boot goes in the transmission at the shift lever.
The large boot goes in the floor sheet metal at the shift lever.
If your 1200 is missing the large one, once you fit one, it will be oh so quiet. The small one is mainly to keep dirt and water out of the gearbox.
datsunbeginner
Posted: 2014/9/12 12:31  Updated: 2014/9/12 12:31
Thanks for clearing that up DD. I am missing both. I did not realize there was two boots per vehicle.
