Main : Mechanical GX Block
[<   Previous  301  302  303  304  305  306  307  Next   >]
GX Block
GX BlockPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/3/13 6:05    Tell a friendTell a friend
Hits5757  Comments11    0.00 (0 votes)0.00 (0 votes)
B110
datto1000wagon
Posted: 2009/3/13 7:30  Updated: 2009/3/13 7:30
 Re: GX Block
has your normal tappet cover though
and the front pulley looks to be off a later model 120y
wheres this? yahoo japan?
Posted: 2009/3/13 7:53  Updated: 2009/3/13 7:53
 Re: GX Block
Yes, YJ.
The interesting thing here is I can clearly see "H10" cast into the block. And of course the large-hole GX head.
Good eyes on that valve cover.
datto1000wagon
Posted: 2009/3/13 7:58  Updated: 2009/3/13 7:58
 Re: GX Block
and the water pump isnt a gx item either
Posted: 2009/3/13 8:11  Updated: 2009/3/13 8:11
 Re: GX Block
1200s with A/C got a double-groove pulley.
How's the water pump differ?
conehead
Posted: 2009/3/13 8:15  Updated: 2009/3/13 8:15
 Re: GX Block
years ago i has a complete genuine gx
engine, the block was painted orange/red
and looked factory? anyone?
datto1000wagon
Posted: 2009/3/13 10:23  Updated: 2009/3/13 10:23
 Re: GX Block
pretty sure the water pump had something for the water heated manifold
not %100 sure though
Fandatstick
Posted: 2009/3/14 11:51  Updated: 2009/3/14 11:51
 Re: GX Block
Quote[The interesting thing here is I can clearly see "H10" cast into the block.]Quote
What's the significance of the H10 casting?
Posted: 2009/3/14 16:35  Updated: 2009/3/14 16:35
 Re: GX Block
"H10" is the "applied model" code for early Datsun 1200.
Here's an A12 with "M08" applied model for Datsun E10 Twin-Carb
lukeADE
Posted: 2009/3/14 23:10  Updated: 2009/3/14 23:10
 Re: GX Block
According to the list there DD, isn't the H10 code just a standard 1200 block? On the list, the applied model number is H24 for the GX sedan?
Or is that the point... the engine is being sold as a GX, but it's just standard
Posted: 2009/3/15 0:50  Updated: 2009/3/15 0:50
 Re: GX Block
GX block and standard block are the same part number. There is no difference. The GX uses a different camshaft, maybe the water tube, and usually the pistons. So the engine assembly part number is different, but not the block part number.
