Main : Mechanical A15T B10 1000 sedan.
[<   Previous  267  268  269  270  271  272  273  Next   >]
A15T B10 1000 sedan.Popular
SubmitterdatsonovicMore Photos from datsonovic   Last Update2009/7/13 3:12    Tell a friendTell a friend
Hits5332  Comments9    0.00 (0 votes)0.00 (0 votes)
The "new" second hand A15 in my `67 1000 sedan.
Anonymous
Posted: 2009/7/13 4:38  Updated: 2009/7/13 4:38
 Re: A15T B10 1000 sedan.
is that a frank the dolphin trianer manifold cleaned up there?
what compressor specs you running, inlet and exhaust side?
should boogie.
ROConnor
Posted: 2009/7/13 4:48  Updated: 2009/7/13 4:48
aw I dont know? thous are pretty heavy!
datsonovic
Posted: 2009/7/13 5:22  Updated: 2009/7/13 5:22
No I`v had this set-up for about 10 years now, But it does look sexy with a fresh coat of pot-belly black on it.
Im not sure of the specs. of the compressor/exhaust, The compressor housing appears to be a NISSAN branded item (NISSAN MOTOR 4), the exhaust housing has 0.36 cast in the side,
Im looking forward to getting the motor back up to full boost, I just cant seem to get the clutch to hold at any thing higher than about 10psi (with the old box and clutch she would hold 30psi+).
A14force
Posted: 2009/7/13 10:09  Updated: 2009/7/13 10:09
have your flywheel modified to take a 200mm L series pressure plate. There is an off the shelf driven plate to suit the 56/60 gearbox spline. (If you're even running one of those) 36% more area = lots of grip, and not much slip.
D
Posted: 2009/7/14 3:33  Updated: 2009/7/14 3:33
From: under the Firmament LOL no twiglight effect BS
I still fail to see where the pot belly black is?
Beautiful colors and a great little motor.
would love to know what it makes in the quarter mile
and also the compressor housing size.
Unfamilia dont think its a dolfin-mani.
datsonovic
Posted: 2009/7/15 9:22  Updated: 2009/7/15 9:22
Pot belly black is on the exhaust manifold and housing.
This same setup with a four speed ran a 12.7,
I think I saw some sort of AE86/SR20 hybrd clutch set-up on this site somewhere, im running a RPM P/Plate and its next to useless.
G O T H E D A T !!
steveo
Posted: 2009/7/15 13:22  Updated: 2009/7/15 13:22
Good to see it still going!
Have you freshened up the engine? or just cleaned up the engine bay?
What gearbox did you previously run? and what gearbox/clutch package you running now?
D
Posted: 2009/7/15 16:21  Updated: 2009/7/15 16:22
I remember reading somewhere he has an escort gearbox
Im interested to see how the bellhousing is modified
as I want to cut and shut a supra bellhousing.
I also know of another member who did the same using
a ford falcon T5 to an A series using cut and shut
bellhousings. Love to know how everything is aligned
to make sure the imput shaft is dead on.
