[< Previous 265 266 267 268 269 270 271 Next >]
Ignition Switch Comparison
ddgonzal 2009/8/2 9:28 Tell a friend
15629 4 10.00 (1 vote)
B110 Small vs B110 Large
* I think the B110 switch here is a 1971 USA model. It has four-connectors and wont fit a five-connector harness due to the molding.
* The 1972-1973 USA switch has five connectors
The B110 small and large are wired differently! So don't even try to swap them them. |
| Poster |
Thread |
| ddgonzal |
Posted: 2004/10/17 4:09 Updated: 2009/8/2 9:27 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: Ignition Switch Comparison 1972 has a larger-diameter switch with two mounting lugs. 1971 is smaller with one mounting lug.
The 1971 'Small' switch has four spade terminals. The 1972 and newer 'Large' adds the "Accessory" position and so has five spade terminals.
B110 North American Wiring W - B BW - IG BW - ACC* BY - S BR - R *1972, 1973 only
B210 North American Wiring W - B BW - IG LW - ACC YB - S BR - R
Switch internal connections: Off - no connections Accessory - Battery (hot) to ACC Run - Battery (hot) to ACC + IG Start - Battery (hot) to IG + Resistor + Start *Starting with 1974 automatic models and all newer, ACC is also hot while in the Start position.
LB110 wiring follows:
IG - Ignition. This connects to two things: 1. Directly to Ballast Resistor (non-coil side). If equipped with optional factory tachometer, this circuit goes through tachometer 2. To IG circuit of fuse box
S - Start circuit. This is connected only to the: 1. Solenoid on the starter
B - Battery (always hot) 1. Battery + terminal, through the fusible link 2. Fuse box "B" side 3. Alternator "A" large output wire 4. Voltage regulator "A" terminal
R - Resistor. Connects directly to: 1. Coil + terminal 2. Ballast resistor (coil side)
ACC - Accessory circuit. Connects to: 1. Radio (through inline fuse) .. 1971 Radios connect to fuse box L wire (always hot) 2. Optional heated rear window glass (1972-North America, 1973-Canada only) Note that this circuit does NOT go to the fuse box, as does Bat and IG.
Wire color codes B - Black W - White R - Red Y - Yellow G - Green L - Blue BW - Black wire with White stripe
| Poster |
Thread |
| A14force |
Posted: 2004/10/18 0:18 Updated: 2004/10/18 0:18 |
No life (a.k.a. DattoMaster)   Joined: 2003/12/3 From: Christchurch NZ Posts: 3707 |
 Re: Ignition Switch Comparison I have used a 310 ignition unit complete on my 1200. The 310 was an "79 or "80 model. I can't remember what year the coupe was I took the 1200 loom out of.
| Poster |
Thread |
| ddgonzal |
Posted: 2009/8/2 7:23 Updated: 2009/8/2 9:19 |
 Re: Ignition Switch Comparison Yes I found the Large B110 switch interchanges with both Datsun 210 (B310) and Datsun 310 (N10).
