Main : Mechanical : Engine 13001-H6200 Camshaft Specs
[<   Previous  1504  1505  1506  1507  1508  1509  1510  Next   >]
13001-H6200 Camshaft SpecsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/8/22 22:30    Tell a friendTell a friend
Hits3891  Comments5    0.00 (0 votes)0.00 (0 votes)
For A14 1975-1978, also 1973 stroker A13.
256/248 duration
From the 1978 B210 Factory Service Manual (North America)
SunnyDaze
Posted: 2017/8/31 5:43  Updated: 2017/8/31 5:43
 Re: 13001-H6200 Camshaft Specs
Be great to know what the lift of this cam is.
Posted: 2017/8/31 7:39  Updated: 2017/8/31 7:43
Lift is 0.324 inch. this is the 6000 RPM cam (A14T used 6400 RPM cam, overdrive A14s used 5600 RPM cam)
SunnyDaze
Posted: 2017/9/7 3:20  Updated: 2017/9/7 3:20
Many thanks!
vixen
Posted: 2017/10/6 8:13  Updated: 2017/10/6 8:13
thought I mite throw this number into the mixing pot and see what comes up
13001-H2312
Posted: 2017/10/7 5:19  Updated: 2017/10/7 5:19
Yes, the GX cam (H23) is higher RPM (therefore making more HP). However it doesn't fit A13/A14/A15 engines. H57 cam is the same profile for the newer engines
H23: 1970-1973 6400 RPM cam
H57: 1973-2008 6400 RPM cam
H62: 1973-2008 6,000 RPM cam
13001-H5700 A12T, A14E/A15E (same grind as GX)
