Main : Mechanical : Suspension Camber / Castor Plates
[<   Previous  283  284  285  286  287  288  289  Next   >]
Camber / Castor PlatesPopular
SubmitterracetechMore Photos from racetech   Last Update2009/9/1 9:15    Tell a friendTell a friend
Hits2919  Comments5    10.000010.00 (1 vote)
New set
Uses 14mm Rose Joint and HT bolt
14mm looks a lot better than the previous 12mm bolt
Strut Brace
b310gx
Posted: 2009/9/2 1:28  Updated: 2009/9/2 1:28
 Re: Camber / Castor Plates
The air cleaner you made for the Hitachi's is similar to one a friend made for me. Is it large enough to fit the factory air trumpets? I got a foam filter from a local manufacturer. My freind used the air filter from an Australian XD Falcon as a template, was big enough to cover both carbies.
racetech
Posted: 2009/9/2 7:33  Updated: 2009/9/2 7:33
I just looked around at the parts stores for n standard filter big enough and used that as a template to cut the stainless.
Anonymous
Posted: 2009/9/1 23:01  Updated: 2009/9/1 23:01
did the 12mm bolt flex or not fiar as weel as expected?
racetech
Posted: 2009/9/2 7:37  Updated: 2009/9/2 7:37
No, had no issues at all, even checked the bolt after removing it, not a hint of it being bend.
The real reason for a bigger bolt was the rabbit shocks, they have 14mm thread and had to get rose joints to fit, and then also make the slot in the plate to suite the 14mm bolt.
