Main : Mechanical : Suspension Datsun B140 Coil Overs
[<   Previous  284  285  286  287  288  289  290  Next   >]
Datsun B140 Coil OversPopular
SubmitterracetechMore Photos from racetech   Last Update2009/9/1 9:11    Tell a friendTell a friend
Hits3592  Comments3    0.00 (0 votes)0.00 (0 votes)
Original Datsun B140 Struts Cut down.
VW Rabbit Monroe Gas Inserts
Mukono
Posted: 2019/3/16 13:02  Updated: 2019/3/16 13:02
Not too shy to talk
 Re: Datsun B140 Coil Overs
What are the caliper bolt spacing for these?
Posted: 2019/3/18 8:25  Updated: 2019/3/18 8:25
Those look modified to me. Or maybe a different year than other B140
B140 had 84mm bolt spacing and was same as B120/B210. Came with either Japan calipers (Mitsubishi) or local-source Girlock calipers. And using factory caliper adapter bracket
Posted: 2019/3/20 7:47  Updated: 2019/3/20 8:40
I used Windows Photos to brighten the photo and increase contrast and now the details can be seen
There are drum brake struts (early B140 1980-1985 had drum brakes) with some kind of bracket bolted on
27207
the original poster (racetech) said: "My ute ... Front: Nissan Sentra 160SI Vented discs and calipers". It was a 1982 Datsun 1400 bakkie
