Main : Mechanical : Engine Starter Comparo
[<   Previous  1356  1357  1358  1359  1360  1361  1362  Next   >]
Starter Comparo
Starter ComparoPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2009/11/15 5:15    Tell a friendTell a friend
Hits2049  Comments9    0.00 (0 votes)0.00 (0 votes)
L-series vs A-series starting motor
a12grunt
Posted: 2011/12/5 12:35  Updated: 2011/12/5 12:35
 Re: Starter Comparo
dd,
can an l series starter be used on an a12 engine and work?
thanks
Posted: 2011/12/5 20:25  Updated: 2011/12/5 20:26
 Re: Starter Comparo
I don't think so, because the A-series has the mounting bolts off center of the shaft, while the L-series appears to be more or less centered:
A-series:
a12grunt
Posted: 2011/12/6 10:36  Updated: 2011/12/6 10:36
 Re: Starter Comparo
thanks dd,
other than tech wiki suggestions,does anyone know if there are other known straight fits from other cars/engines that could be swapped and work?
supafatto
Posted: 2011/12/6 10:48  Updated: 2011/12/6 10:48
 Re: Starter Comparo
why do u want another starter to fit an A series??
a12grunt
Posted: 2011/12/6 11:32  Updated: 2011/12/6 11:32
 Re: Starter Comparo
i got an l18 starter which looked similar other than mounting bolts position.so just curious which other starters could be used instead.have read on wikipedia of other car model swaps i.e brakes/trans/struts etc
cheers
Anonymous
Posted: 2011/12/6 13:59  Updated: 2011/12/6 13:59
 Re: Starter Comparo
give me a L series starter and alternator... i could use them
Posted: 2011/12/7 1:21  Updated: 2011/12/7 1:21
 Re: Starter Comparo
Generally, no. Not with Datsun, and not with Ford, and not with others. Each engine family generally has its own starter housing.
You might be able to remove the housing (end casting) from the old A-series starter and fit it to the L-series starter. If they are both Hitachis that might work. But if one is a Mitsubishi and the other a Hitachi I doubt it would interchange.
D
Posted: 2011/12/7 5:47  Updated: 2011/12/7 5:47
From: under the Firmament LOL no twiglight effect BS
 Re: Starter Comparo
my original a10 starters where huge compared to later a15 vanette ones so I quickly changed them and saved a fair bit of weight right there.
a12grunt
Posted: 2011/12/7 8:07  Updated: 2011/12/7 8:07
 Re: Starter Comparo
D very smart ideas of saving weight.
Unfamilia u can have the L18 starter.ive got it at home.The alternator is on the engine in vehicle in storage.
dd,i know its abit extreme but glad to know atleast one can get a custom very light housing to house the a12 starter.
cheers
