Main : Mechanical : Drive Train My new diff
[<   Previous  722  723  724  725  726  727  728  Next   >]
My new diff
My new diffPopular
SubmitterDavemanMore Photos from Daveman   Last Update2003/8/26 13:20    Tell a friendTell a friend
Hits7432  Comments21    0.00 (0 votes)0.00 (0 votes)
This is my first effort at posting a photo. This is my new diff to sit behind my CA18. It's a borgwarner type out of an R31 pintara which means I get the rear discs aswell:) I got it all cut and made to fit for $450 which I reckon was a bargain.
datsik
Posted: 2006/4/27 16:44  Updated: 2006/4/27 16:44
 Re: My new diff
$450 is a blo ody bargain!! considering that people are advertising 1200 ute diffs for $300.
Daveman
Posted: 2006/4/28 2:53  Updated: 2006/4/28 2:53
 Re: My new diff
Yeah it was cheap but that didn't include the price of the diff itself. Factor in anywhere from $150 to $300 for a complete diff disc to disc on top of the $450.
I paid $250 for the original diff so it cost $700 all together. Ute diffs have been known to go for up to $500-600 so it's a little bit more for a lot more assurance.
D
Posted: 2006/4/28 4:27  Updated: 2006/4/28 4:27
From: under the Firmament LOL no twiglight effect BS
 Re: My new diff
Who did the work thats cheap as!!!!!
Tell us the suspense is killing us!!
Did he he spline the axles? Harden the splines?
low1000
Posted: 2006/4/28 6:44  Updated: 2006/4/28 6:44
 Re: My new diff
hey,
pintara axle assembly and skyline ones look exactly the same from the outside and have the same brake set up but the axels and centers are different.
skyline = 28 spline and PHAT axles
pintara = 25 spline axles and puny axles
so i hope you got a 'line diff hey.
Elliott
Daveman
Posted: 2006/4/28 6:52  Updated: 2006/4/28 6:52
 Re: My new diff
Work was done by Ballarat Driveline Services.
All the invoice says is that housing was modified as per sample given (H145 diff supplied) and axles resplined to suit.
I don't know if the splines got re-hardened. Probably not.
I didn't mind taking it to ballarat because I have relatives there who eventually brought the diff back to melb for me when they came down.
phunkdoktaspok
Posted: 2006/4/28 9:11  Updated: 2006/4/28 9:11
 Re: My new diff
Whats the story behind why the other diff was cut up?
The price is definately cheap.
Daveman
Posted: 2006/4/28 16:57  Updated: 2006/4/28 16:57
 Re: My new diff
The outer parts of the housing of the H145 have been welded into the Borg Warner housing so that all the mounts are exactly the same. At the outer flanges the Borg Warner bits have been attached so the bearings and seals fit over the axles. It's a big mix and match but it bolts in like an H series diff with all stock U bolts etc.
D
Posted: 2006/4/30 5:50  Updated: 2006/4/30 5:50
 Re: My new diff
Pintara = 25 spline and puny axles
Is the Pintaras "puny axles" size the reason why the 1200 axles housing ends where able to fit?
As for puny axles, Im sure these axles are strong enough to handle almost double the abouse of h145.
I still wonder why the whole pintara rear end couldnt just be shortened with disks and all and just use the 1200 mountings?
Now you will have to use 1200 bearings and not the bigger pintara ones?
Davo1200
Posted: 2006/4/30 6:36  Updated: 2006/4/30 6:36
 Re: My new diff
You mean like this?
[url=][url=http://datsun1200.com/modules/myalbum/photo.php?lid=640]
This is basically the same diff as above but original housings was shortened instead of the cut and weld of the h145 housings.
The track width was shortened to 1405mm
phunkdoktaspok
Posted: 2006/4/30 7:29  Updated: 2006/4/30 7:29
 Re: My new diff
Looks like it was more work than if they were to just shorten the one diff and provide bigger U bolts and new shackle plates.
Definate bargin when you look at the work involved. And a bargin is definately what we always want
D
Posted: 2006/4/30 8:11  Updated: 2006/4/30 8:11
 Re: My new diff
You mean like this?
Sorry if it sounds like Im baggin it, im seriously not!
It seems more work to get what you got done and that it should have cost more.
I want to get the same kind of work done with a different diff.
I want to get my diff shortened and mated to skyline axles with skyline or pintara disc brake setup.
As in the pic it has an finned alloy housing and sump with fins at the bottom.
It has adjustable torque bias and clutch pack LSD.
WhiteSedan
Posted: 2007/7/2 14:53  Updated: 2007/7/2 14:53
 Re: My new diff
D, is that a alfa diff?
Daveman
Posted: 2007/7/2 15:08  Updated: 2007/7/2 15:08
 Re: My new diff
An old pic I know but thought I'd shed a little more light on it. It turns out that it was a 28 spline skyline diff after all. About the housing, it still uses the large bearings as the outer flanges are welded on from the BW diff. The sections with original mounts are from the H145 and the 28 spline axles do fit through these sections. I guess what the diff guy achieved was a genuine "bolt in" diff upgrade.
D
Posted: 2011/9/1 4:36  Updated: 2011/9/1 4:36
 Re: My new diff
bump
Cheapest place for diff shortening yet
and we must take note for those interested recently!!!!
Also Simon is in the area for a dyno
B120dat
Posted: 2003/8/26 13:31  Updated: 2003/8/26 13:31
 Re: My new diff
looks like ya pulled half ya house down with all those bricks , but yeah that diff looks pretty strong, what does it wiegh? i bet no where near a 9inch, that some lads want for the look does it have LSD?
jack
Posted: 2003/8/27 1:41  Updated: 2003/8/27 1:41
 Re: My new diff
Not sure if the pintara diff is the same as the skyline diff (pretty sure its not but...), the R31 Skyline single spinners can be replaced with the LSD centre quite easily and readily.
Daveman: Why did they have to cut up your old diff housing?
Daveman
Posted: 2003/8/27 6:23  Updated: 2003/8/27 6:23
 Re: My new diff
Hehe! The bricks are because of my lack of jack stands! My friends call me "safety Dave" but I swear the bricks are pretty solid. The diff isn't LSD but before I went through with it I was instructed by the bloke that did it that the LSD centres out of the old falcon BW diffs will fit. Also the old diff got cut up because he welded the parts of the old H145 with the brackets for the leafs in the new housing. It means I can still use the original U bolts and brackets.
DatA15
Posted: 2004/1/20 14:08  Updated: 2004/1/20 14:08
 Re: My new diff
well as everybody sais theres a little dodgeyness in every datto owner.
at least the bricks are getting used...
Dodgeman
Posted: 2004/1/20 14:16  Updated: 2004/1/20 14:16
 Re: My new diff
Hey, nice bricks.
Did the diff man shorten the axles by cutting & welding, or were the originals from this rear axle assembly resplined?
thomo
Posted: 2006/4/27 16:01  Updated: 2006/4/27 16:01
 Re: My new diff
WOULD LIKE TO NO ABOUT AXLES TO/HOW MANY SPLINES ? 120Y BORGY AXLES ???
LAGWAGON
Posted: 2006/4/27 16:04  Updated: 2006/4/27 16:04
 Re: My new diff
R31 28? spline i think. much stronger than the 120y borgy!
