Main : Mechanical : Engine oval port manifold
[<   Previous  1359  1360  1361  1362  1363  1364  1365  Next   >]
oval port manifold
oval port manifoldPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2010/2/18 6:13    Tell a friendTell a friend
Hits2645  Comments8    0.00 (0 votes)0.00 (0 votes)
hmmm
ROConnor
Posted: 2010/7/27 8:49  Updated: 2010/7/27 8:49
 Re: oval port manifold
I dident mean because its a single plane manifold just the large volume of the plenum would kill throtle responce.
Posted: 2017/1/23 20:52  Updated: 2017/1/23 21:08
Yes, I would think so. Throttle "response" means tractability, how it responds when transitioning from idle to part throttle, and from low airflow to high airflow
I would guess that the big plenum and big runners help with high-airflow situations, for example full-throttle at higher RPMs
Corollas runs them from factory in the K engines
* This design: 4 runners off the plenum
* factory A12/A14 design: 2 runners off the plenum
The factory Corolla manifolds use a small plenum volume and use a hot-spot (heated manifold). Which this manifold doesn't have ... hotspot helps tremendously with part-throttle response
3K intake manifold from 1978 Corolla
3K manifold has Heat Riser connection to exhaust manifold
Rowland A14-Weber manifold
ROConnor
Posted: 2010/2/26 6:03  Updated: 2010/2/26 6:03
I recon youd get a killer flatspot with that mannifold
Posted: 2010/2/26 6:16  Updated: 2010/2/26 6:16
You might be right. Single plane manifolds are good for high-RPM, not so good for wide torque band.
D
Posted: 2010/7/25 4:02  Updated: 2010/7/25 4:02
From: under the Firmament LOL no twiglight effect BS
these manifolds are not as bad as people think
and Fiat also for many years in same capacities
as in our beloved A and are wonderful.
You just have to look at the economy and performance
of the fiat engines and realize that the design
does help performance but also torque.
Chryslers version for the slant 6 is used still this day
in John Deere tractors and is the same as the pic but with
6 runners.
andy-roo
Posted: 2010/2/25 19:48  Updated: 2010/2/25 19:48
wow that looks nice an looks like it bolts strait to a weber.?
Posted: 2010/2/25 20:08  Updated: 2010/2/25 20:08
Looks like it to me too.
Who makes this manifold?
Dundee1000
Posted: 2010/2/26 4:26  Updated: 2010/2/26 4:26
