Main : Mechanical : Brakes Remote Brake Booster
[<   Previous  158  159  160  161  162  163  164  Next   >]
Remote Brake BoosterPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2010/2/19 7:07    Tell a friendTell a friend
Hits3875  Comments5    0.00 (0 votes)0.00 (0 votes)
1975 1200 truck
estyre
Posted: 2010/5/20 15:54  Updated: 2010/5/20 15:54
 Re: Remote Brake Booster
how would i go about setting up and making remote booster
Posted: 2010/5/20 22:24  Updated: 2010/5/20 22:24
1. use a section of pipe to space it out from the firewall
2. lengthen the master cylinder pushrod
This is the technique used by Nissan on LHD Datsun 620 trucks.
ssskiwi
Posted: 2010/5/21 10:31  Updated: 2010/5/21 10:31
You can use something like a VH44 remote booster instead. Doesn't need any physical connection to the pedal, just hyd pressure in, hyd pressure out and a vacuum source. Used to use one in my rally car with a valve on the vacuum line, could then turn it on or off and thus change F/R bias from boosted to none boosted. Worked well.
datsa73
Posted: 2010/2/22 6:05  Updated: 2010/2/22 6:05
That battery could turn over a bulldozer.
