Main : Mechanical : Engine areas of inconsistancy in Knife edging?
[<   Previous  1335  1336  1337  1338  1339  1340  1341  Next   >]
areas of inconsistancy in Knife edging?Popular
SubmitterDMore Photos from D   Last Update2010/3/30 13:04    Tell a friendTell a friend
Hits2111  Comments5    0.00 (0 votes)0.00 (0 votes)
this is for Chris´s thread
ROConnor
Posted: 2010/4/1 9:33  Updated: 2010/4/1 9:33
 Re: areas of inconsistancy in Knife edging?
Are those areas even machined??
D
Posted: 2010/4/3 3:21  Updated: 2010/4/3 3:21
From: under the Firmament LOL no twiglight effect BS
Its pretty obvious they where but just not well in this area
clyons8
Posted: 2010/4/3 4:03  Updated: 2010/4/3 4:04
The photograph does not properly exhibit the extent of work as the contrast is obviously excessive and the light not uniform. Considering the image itself is no larger than 60kb I wouldn’t expect anyone of any (feasible) technical knowledge to make any judgment on workmanship, not just yet anyway. The manner in which the crank was machined also plays a slight trick on the eye and this particular camera position is certainly unflattering to that detail.
In terms of the actual machining, the die has not been passed across the specified areas (to be removed) in a direct straight line, instead it has been moved across in a curved manner which creates the illusion that I suspect you are seeing in the photo. This crank is different to the Knife Edged items you guys are so used to seeing in that its shape across the face of the lobes (and all other machined planes) is distinctly (& significantly) convex which is the detail that I insist this photograph has excluded.
A14force
Posted: 2010/3/31 12:26  Updated: 2010/3/31 12:26
someone elaborate! I plan to do this soon. And I crave input from someone who knows their sh*t!
