[< Previous 1233 1234 1235 1236 1237 1238 1239 Next >]
Comparo: Rocker shaft oil passage
ddgonzal 2010/7/25 18:44 Tell a friend
2939 2 0.00 (0 votes)
Early vs. Late A-series oiling passage
Early: separate hole through head gasket, two blinds in head Late: uses head bolt hole of gasket, two blinds in block |
| Poster |
Thread |
| ddgonzal |
Posted: 2010/6/9 5:36 Updated: 2010/6/9 5:36 |
Moderator   Joined: 2001/5/3 From: Kent, WA Posts: 31866 |
 Re: Comparo: Rocker shaft oil passage i wonder if Nissan did this to simplify the head machining
or
to remove the extra hole from the head gasket? They did have trouble with the early head gaskets, and added an o-ring in the revised B110 head gasket.
