Main : Misc Henry's CA18DET project 04
[<   Previous  6741  6742  6743  6744  6745  6746  6747  Next   >]
Henry's CA18DET project 04Popular
SubmitterjackMore Photos from jack   Last Update2003/9/4 13:37    Tell a friendTell a friend
Hits2827  Comments1    0.00 (0 votes)0.00 (0 votes)
The reason why a standard S13 dump pipe can't be used: it actually sits against the idler arm.
Demojob
Posted: 2003/9/16 10:05  Updated: 2003/9/16 10:05
 Re: Henry
To overcome this problem you cut the dump pipe where it kinks in the middle and turn the bottom piece until you get the desired clearence then get it rewelded it pretty much needs to be rotated 180 degrees give or take a bit, for it to fit right.
I've got my dump pipe in getting welded up at the moment
Cheers
Damo
