Main : Mechanical : Engine Firing Order
[<   Previous  1226  1227  1228  1229  1230  1231  1232  Next   >]
Firing Order
Firing OrderPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2010/8/7 6:44    Tell a friendTell a friend
Hits12950  Comments3    0.00 (0 votes)0.00 (0 votes)
Distributor
* Green arrow is direction the vacuum advance faces
* Yellow arrow is rotation of the rotor
Firing order goes according to Yellow arrow (opposite of green arrow)
adameimran
Posted: 2011/7/18 4:28  Updated: 2011/7/18 4:28
 Re: Firing Order
very goood info. tq
spatchcock
Posted: 2011/7/22 15:02  Updated: 2011/7/22 15:02
 Re: Firing Order
mine started where the 3 is. went around in the same order but just one step over.
is this bad?
Posted: 2011/7/22 22:33  Updated: 2011/7/22 22:34
 Re: Firing Order
Yes that is fine. When put the engine to TDC mark for #1 cylinder, note where the rotor points, and start from there. The photo here is the stock distributor location. But it can work correct in other positions.
You would have to remove the dizzy and retime it to make it look the same. It is not necessary.
