Main : Racing : Drag Z24 Oil Pan
[<   Previous  17  18  19  20  21  22  23  Next   >]
Z24 Oil Pan
Z24 Oil PanPopular
Submitterdatsa73More Photos from datsa73   Last Update2010/12/17 23:09    Tell a friendTell a friend
Hits2321  Comments6    0.00 (0 votes)0.00 (0 votes)
Another morf'd product by me. Holds 5 quarts.
A14force
Posted: 2010/12/18 23:13  Updated: 2010/12/18 23:13
 Re: Z24 Oil Pan
Quite a piece of work Ernie. I'm planning a muscle into import swap in the future, and my sump will require similar jiggery-pokery to what you've conjured up here.
PIGDOG
Posted: 2010/12/19 1:55  Updated: 2010/12/19 1:55
 Re: Z24 Oil Pan
so clearly you fancy your welding skills more than your metal bending skills
datsa73
Posted: 2010/12/20 17:29  Updated: 2010/12/20 17:29
 Re: Z24 Oil Pan
Some of the edges were scored so I could get a nice even bend so they had to be welded. Have had it filled with water for 2 days now with no leaks.
D
Posted: 2010/12/21 10:03  Updated: 2010/12/21 10:03
From: under the Firmament LOL no twiglight effect BS
 Re: Z24 Oil Pan
misses the crank, sits as low as possible
doesnt leak, thats all thats needed good job!
PIGDOG
Posted: 2010/12/23 0:43  Updated: 2010/12/23 0:43
 Re: Z24 Oil Pan
need to really fill it with hot oil to see if it leaks, my L series one held all kinda of stuff for ages while sitting on white paper and there were no leaks...until it was run on the car then there was a few
datsa73
Posted: 2010/12/23 22:09  Updated: 2010/12/23 22:09
 Re: Z24 Oil Pan
I hope that doesn't happen. Worked hard on this thing to start over.
